Thread: very basic cad cam software
i still seam to be having the same problem? i made the holes 3.2mm but it is not till i reduce the cutter to 2.6 that it seams to want to include them? any ideas is there another setting i have got wrong? I have attached the file hopefully it shows the setting. many thanks
Sorry I can't open a cb file. ..Clive
22-02-2015 #3
23-02-2015 #5
I have been routing all my holes this way for years. I wonder if Charlie is putting his cutter paths on the circle centre with no offset to the inside of circle? To my mind the problem will be in that direction. G.
23-02-2015 #6
USE A PECK DRILL like Eddy suggested. Can't interpolate 3mm hole with a 3mm cutter simple as that.!
23-02-2015 #7
23-02-2015 #8Spelling mistakes are not intentional, I only seem to see them some time after I've posted
23-02-2015 #9
So what if there are say 166 holes.? Do you change ever piece of geometry.? how longs that going to take.! (Answer In this case would actually be to tell Cam tool is 2.99mm but hole will still be wrong size)
What if the holes are for dowl pins and need to be exactly 3mm.? In this case a 3mm endmill won't work so again more time wasted swapping out endmills.
Maybe I'm being a bit Pedantic here but Better to get into a habbit of using the easiest and less disruptive option which in this case would have been a Peck drill than changing geometry or using fudges like under sizing tools in Cam.Last edited by JAZZCNC; 23-02-2015 at 02:51 PM.
Basic Frame Design
By Ross77 in forum Machine Frames & BedsReplies: 0Last Post: 04-01-2015, 01:33 AM -
The ideal CNC machine for my (basic)needs?
By mark84 in forum Machine DiscussionReplies: 9Last Post: 12-03-2014, 10:56 AM -
NEW MEMBER: Basic 3d milling
By proddy in forum New Member IntroductionsReplies: 3Last Post: 08-06-2012, 12:11 AM -
Advice on some basic tools
By GTJim in forum General DiscussionReplies: 10Last Post: 22-09-2011, 12:16 PM -
Which Basic Lathe
By graysclassics in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 06-07-2011, 10:39 PM
