Thread: redsail m500
Its 8.1 (not sure if that makes much difference) . Where would i be able to find out this info?
No idea, I steer clear of Win8, but in Win7 it is Control Panel/Folder options under the view tab.
24-02-2015 #3
I don't seem to be able to find anything that works in control panel....i mean to load files i don't see?
Any other ideas...
Thanks in advance guys
Calida
24-02-2015 #4
24-02-2015 #5
I meant that you should make sure that no files are hidden by the system.
From what I have seen of Win8, it is going away from the system engineers dream of something that is understandable, and can be patched if it don't do what you want.
When I was a programmer in the 60's, I could patch programs by stopping them, altering bytes in memory and then setting it running again. Up until Win98 I could do much the same. I started to lose interest with XP and now with Win7 I don't give a flying f**k. My attitude to Win8 is another step in the same direction.
24-02-2015 #6
Can you look in the system (Control Panel/System/Device Manager) to see that there are no Yellow question marks or other warnings ? If none then I would start to suspect a board failure in the laser machine. Windows should detect the device by Hardware Id and load the drivers off t'interweb if they are properly registered.
But I am starting to run out of ideas on this one.
FOR SALE: redsail c150 laser - ideal plasma conversion
By nobby in forum Items For SaleReplies: 3Last Post: 01-03-2014, 06:17 PM -
Anyone own a Redsail CNC?
By AdrianM in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 13-04-2012, 06:31 PM
