24-02-2015 #1
I'm in the process of building a new control box with higher voltage drivers, new BOB etc.
The front panel will have various new controls such as power on/off, e-stop, ancillaries (lights, pump,etc.), VFD on/off and speed, all of which will be hardware controlled through simple circuits.
I'll also add buttons to control cycle start/feedhold/stop, and feedrate override up/down buttons. I'm hoping to do this bit through something like pokeys. Now to my question.
To control the feedrate override up/down I will have 2 seperate momentary push button switches to increment the feedrate in small steps, emulating a keyboard input. Is it possible instead to employ some sort of rotary momentary switch? The idea being that as I turn an infinite dial it clicks past detents which send a pulse to the pokeys system to emulate a key push. I think there would be two sets of detents so it would know whether the dial is being turned clockwise or anti-clockwise.
I've been looking at this:
http://www.ebay.co.uk/itm/5-Pin-Digi...ht_1230wt_1190
Would this do it? If so, how would you expect the 5 pins to be wired up?
Use spindle torque to control feedrate?
By Jonathan in forum Tool & Tooling TechnologyReplies: 4Last Post: 02-05-2014, 10:37 AM -
feedrate stuck on low
By routercnc in forum Machine DiscussionReplies: 1Last Post: 24-04-2014, 10:24 PM -
DIY Rotary Encoders?
By birchy in forum Electronic Project BuildingReplies: 3Last Post: 15-09-2013, 03:09 PM -
How Rotary Broaching Works
By steve3d in forum Tool & Tooling TechnologyReplies: 0Last Post: 18-01-2011, 03:17 AM -
Bearings(Rotary)
By GeorgeD in forum Linear & Rotary MotionReplies: 7Last Post: 14-08-2010, 05:50 PM
