  1. Nice looking little machine Joe, like the housing too. What do you make out of interest?
    Joe's Avatar
    Lives in Shropshire, United Kingdom. Last Activity: 28-01-2020 Has been a member for 9-10 years. Has a total post count of 31. Received thanks 1 times, giving thanks to others 1 times.
    Yes the enclosure is a good thing to have, the machine and all its electronics are in the enclosure and then I have storage space in the bottom.
    I cut mainly aluminum, plastics, modelling foam and wood, a real mixture really . It can machine steel but I try to avoid it when I can.
    all the ball screws are 1605 from linearmotionbearings and they seam accurate but I can get up to 0.09mm of "backlash" or flex when I push and pull on the machine, but the accuracy/repeatability of actual parts is more like 0.03mm which is really good. I am thinking of upgrading to a branded 20mm screw which should give me a bit more rigidity.
ID:	14776   Click image for larger version.
ID:	14777   Click image for larger version.
ID:	14778   Click image for larger version.
ID:	14779   Click image for larger version.
ID:	14780   Click image for larger version.
    Quote Originally Posted by Joe View Post
    If you actually mean backlash, then 0.09mm is a sign of the ballscrews being damaged, however it sounds like you mean flex in the machine? If that's the case then better rails is one way to help with that.
    You don't need a larger diameter screw - it will only slow things down. The load rating and stiffness of 16mm ballscrews is plenty for the size of your machine.
    Joe's Avatar
    Yes I don't mean backlash as such I mean machine flex around the screw , so cumulative error between the screw support, ballnut and housing ect.
    I wasnt sure about a larger screw and if it would actually improve things, but your right the extra mass will definitely kill acceleration.
  1. advise options needed on laser upgrade/add on
    By george uk in forum Laser Machines & Building
    Last Post: 19-07-2014, 10:54 PM
  2. What is the best way to mark out for bearing blocks and linear rails?
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 18-05-2014, 02:08 PM
  3. Options for installing linear guide rails ?
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 15-10-2011, 12:09 AM
  4. FOR SALE: Linear rail and bearing
    By black5f in forum Items For Sale
    Last Post: 02-07-2010, 07:23 PM
  5. THK linear bearing rails
    By Tonyel in forum Rails, Guideways & Bearings
    Last Post: 01-11-2008, 03:21 PM
