Hi Gav, I mostly use a 6mm cutter, and if worried about hold down just add a few tags. You most certainly do not need 2x25kw vac pumps, I only use 1 x 3.5kw vac pump, but a 7.5kw pump would be better. Some people rout out a holding sheet for repetitive work. That means routing out a groove slightly smaller than the component and putting a rubber gasket in that groove, that means that each workpiece will remain held in position by the vacuum, and the gasket is left undamaged by the cutter. That sacrificial board can then be saved and used for your next batch of the same items. I hope that mall makes sense. G.
26-02-2015 #2
That does make sense Geoffrey, the addition of a gasket was also something I was thinking about but was worried about the rubber/foam/cork getting damaged as I slide the sheets on and off the bed machine. I think a holding sheet will definitely reduce the need for a large pump and give me decent hold down.
Tabs are not an option as I plan to cut almost all the sheet material away so I am left with sawdust and parts :) Hence why I was thinking about painting the holding sheet as the surface area exposed will be quite large.CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
26-02-2015 #3
Make the gasket a nice tight fit in the groove, biggest corner radius you can and only have the gasket 0.3- 0.5mm above the square (say if using a 5mm gasket make the groove 5mm wide and 4.5-4.7mm deep] section groove, this will allow the top sheet to pull down virtually flat whilst cutting, and you should not damage the gasket when removing the sheet. G.
26-02-2015 #4
Where do you buy your gasket material?
ADD ME ON FACEBOOKS
26-02-2015 #5
I buy it on the roll (100M from memory & that lasts ages for me). I normally use 8mm as that suits my bed matrix, but it is available in various dias. Can't remember the company at the moment, but will check down the works and post tomorrow. A quick google search should show it anyway. I think it is called neoprene or butyl rubber. G.
Baltic Birch Plywood availability in the UK
By Ccrewz in forum Marketplace DiscussionReplies: 37Last Post: 08-09-2019, 10:18 PM -
8 x 4 sheet capability
By PSG in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 24-02-2015, 02:25 PM -
RFQ: RFQ - 2 Off Birch Plywood Profiles (overall size 269mm OD)
By pvuk5 in forum Projects, Jobs & RequestsReplies: 0Last Post: 13-10-2014, 10:12 AM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
RFQ: 5 Axis Hole Drilling in Plywood - 1260 holes in 64 boards - help very much needed!
By pjm699 in forum Projects, Jobs & RequestsReplies: 3Last Post: 16-08-2012, 08:50 AM
