    Ok Neale is correct regarding the steppers and current etc. But if you want to future proof your electronic to use on another machine then the drivers you have chosen are not good enough.
    You would be better buying the steppers from cnc4you and using AM882 or EM806 (the newer version) but the AM882 are fine and cheaper as they both can take up to 80 V so then you would need a 70V power supply for them.
    The difference between 36V and 70V is night and day. It is one of the biggest mistakes that people do with using underpowered drives. ..Clive
    Can't disagree with Clive - new machine is being upgraded to EM806 for X and Y. As I said, I doubt if the lower voltage would have been an issue for my current router but that's because it's a pretty ropey machine. New machine deserves better and will get the higher voltage.
  1. Help with 1.5kw Chinese spindle. Wrong plug.
    By adamh in forum Generic Chinese Spindles
    Last Post: 14-01-2014, 07:36 PM
  2. Plug for water cooled Chinese spindle
    By John S in forum Generic Chinese Spindles
    Last Post: 28-08-2012, 05:56 PM
  3. recommended 3d model software for cnc cutting?
    By wyndham in forum General Discussion
    Last Post: 01-01-2012, 05:28 PM
  4. Recommended DAC please?
    By Swarfing in forum Motor Drivers & Controllers
    Last Post: 13-09-2011, 08:14 PM
  5. Most recommended plans??
    By crazy horse in forum Gantry/Router Machines & Building
    Last Post: 03-07-2009, 02:45 PM
