    Sven's Avatar
    Lives in a, Netherlands. Last Activity: 07-05-2020 Has been a member for 9-10 years. Has a total post count of 46. Received thanks 4 times, giving thanks to others 0 times.
    Complete with dust shoe:
    I have the tube clamped to the z-axis, so it can be set to a height.
    The next one would just be on linear rails.
    The height of the clamp is only about 30 mm, that requires cross bracing with the rear of the tube or it will flex at high feeds. (It did with this one)
    The cast aluminium one is much higer, probably will not need cross brace but you can always add it later, should you need it.
    A section of 100 mm pvc pipe can easily be fitted to the 80x80 if you heat it.
    Picture of a few years back:
ID:	14898   Click image for larger version.
  2. Strengthing a steel gantry.
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 07-06-2014, 09:11 AM
  4. FOR SALE: For Sale : Gantry CNC Machine, Bedford
    By pcstru in forum Items For Sale
    Last Post: 05-06-2011, 05:16 PM
  5. BUILD LOG: My flying gantry machine
    By progomez in forum DIY Router Build Logs
    Last Post: 21-09-2009, 10:30 PM
