Hi guys! So what do you think about my bed idea?
I would have the big steel sheet laser cut and holes tapped. Then welded to the square tube frame. Then replaceable aluminium bars on top. I want to have it separated from main frame - for easier transport. That been said... CAD calculates 204 kg for the bed weight
Overkill?
25-03-2015 #2
If you make the 10mm steel base a bit bigger than the strips you can put sides on it and then a drain in one corner and if you use coolant then you can drain it.....if you're not going to use coolant then ignore this
The Following User Says Thank You to njhussey For This Useful Post:
26-03-2015 #3
01-04-2015 #4
Things are moving slow...but at least they are moving forward.
I wanted to do all steel Z-axis but as I had something thrown together in CAD I changed my mind. Main reason is weight. Steel Z will be at least 7-10kg heavier. As my hole gantry is at the edge of using servos I will go with aluminium Z design.
I'm not quite finished alu design but it will be from 25 mm thick material.
Here is a picture of my alu design (left) and steel design (right side).
01-04-2015 #5
06-04-2015 #6
I can't follow the reasoning for not using steel, except for silyavski reasoning. If the gantry is steel, 7-10 kilo'sfor the z-axis will not make things that much different. Except for stiffness!
If the machine is for wood and this big, acceleration is less of an issue than top speed and for top speed stiffness is paramount. And all is designed to be stiff, except for this z-axis....
Besides, you can get 20 Nm steppers of the shelf....Last edited by Sven; 06-04-2015 at 07:20 AM.
06-04-2015 #7
Strengthing a steel gantry.
By gavztheouch in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-06-2014, 09:11 AM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
FOR SALE: For Sale : Gantry CNC Machine, Bedford
By pcstru in forum Items For SaleReplies: 1Last Post: 05-06-2011, 05:16 PM -
BUILD LOG: My flying gantry machine
By progomez in forum DIY Router Build LogsReplies: 29Last Post: 21-09-2009, 10:30 PM
