  1. To work out the critical speed of a screw there is a calculator on our site.
    http://www.zappautomation.co.uk/inde...lculators.html
    In the lower part of this page is a link for the calculator.
  2. The Following User Says Thank You to Gary For This Useful Post:
  3. #2
    To give you an idea I recently built a Slaved axis 4x4 router with 20mm Dia 10mm pitch screws 1700mm length Fixed/Fixed ends with 2 x 3.1Nm steppers running 70Vdc on EM806 digital drives. It safely reached 15mtr/min while testing and probably could have pushed it slightly more but felt no need.
    Machine is actually tuned much lower than this at 10mtr/min rapids to keep a very generous safety margin. 10mtr/min is more than enough speed for machine like this.
  4. The Following 4 Users Say Thank You to JAZZCNC For This Useful Post:
  5. #3
    I am still amazed by the time it takes to get things organized ;)
    So anyways here is the gantry. Bit on a heavy side - 84 kg. For sure there will be some more fasteners, dust collector, cable-chain etc adding weight. Plan is to use 2 x 2000mm ballscrews 2010 to drive it. Fixed/fixed ends. 3,1Nm steppers.
    Can I make it work?
    I dont want to go servos on first build :)
    Now my frame is looking like a toy :) Will make it 100x100mm tube instead 80x80 and beef it. Also I will ditch the bed design and try making some-kind of hybrid from marine plywood and aluminium surface for smaller parts...
    If you guys approve the design I will order screws and rails and stuff from Fred...
    Thanks for listening!
Name:	CNC 1800x750.JPG
ID:	15576   Click image for larger version.
  6. #4
    Quote Originally Posted by toomast View Post
    Can I make it work?
    Yes it will work thou with 83Kg + gantry you'll have lower feed rates than I posted lower down. Think the gantry on that machine was 50Kg.
    Now regards 100mm over 80mm then being totally honest I think this kind of building to excess is unnecssary and the little you gain isn't worth the cost and trouble. 80mm is more than enough for a frame this size. You'll gain more thru less resonance using 80mm or even 60mm but buy a thicker walled tube than going with 100mm thin walled (big base drum) tube.!!. 100mm thick wall tube is expensive and complete OTT for machine this size.
    Other than the OTT build strength of the gantry the only thing I see which I'm not sure about is the flimsy looking ballnut supports on gantry ends and Gantry ballscrew.
    Also not sure to how your mounting the motor and fastening to ballscrew across the gantry because pics don't show it very well. But it looks like your planning on connecting ballscrew to rear shaft of stepper and mounting stepper to a plate using normal stepper mounting holes.
    OR doing reverse and mounting stepper to plate using rear holes and having the front hang out in space connecting to ballscrew.? . . . .Both bad idea.!!
    Can you show better pics of what you have in mind.!
    On the Bed idea.! I see you have large distance from bed frame to spindle and no adjustment which will be fine for wood etc but no so good for harder materials. So if you don't need all the bed then think about a 2 tier setup with the alumnium cutting area raised up to bring material closer to cutter.
    The raised section could be made removable for when full bed needed and using a torsion box setup for stabilty.!
  7. #5
    Here are closer pictures. All laser-cut steel is 8mm and ballnut brackets are welded...
ID:	15581   Click image for larger version.
ID:	15582   Click image for larger version.
ID:	15583   Click image for larger version.
ID:	15584   Click image for larger version.
  8. #6
    So guys do you think I'm OK with the design?
    Next week I want to order screws, rails and other stuff. Unless...
  2. Strengthing a steel gantry.
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 07-06-2014, 09:11 AM
  4. FOR SALE: For Sale : Gantry CNC Machine, Bedford
    By pcstru in forum Items For Sale
    Last Post: 05-06-2011, 05:16 PM
  5. BUILD LOG: My flying gantry machine
    By progomez in forum DIY Router Build Logs
    Last Post: 21-09-2009, 10:30 PM
