21-06-2015 #9
Thanks guys! Improvements implemented.
Yes these are brackets for limit switches. And I have not thought about using only one traveling switch!Those little white brackets sticking out on the end plates are those for triggering limit switches at each end.? . . . If so have you thought about using a traveling switch and save your self a lot of wiring and messing around with brackets etc. I do all my machines this way and it saves alot of work and easy to setup.
Simple and ingenious - for sure I will also implement this!
I will go ahead and order my stuff from BST Automation.
Strengthing a steel gantry.
By gavztheouch in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-06-2014, 09:11 AM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
FOR SALE: For Sale : Gantry CNC Machine, Bedford
By pcstru in forum Items For SaleReplies: 1Last Post: 05-06-2011, 05:16 PM -
BUILD LOG: My flying gantry machine
By progomez in forum DIY Router Build LogsReplies: 29Last Post: 21-09-2009, 10:30 PM
