21-06-2015 #9
Yep, similar. As i described it above. Though tit did not come to my mind to use only one limit switch at Y,
, anyway, i bought more than i needed.
I would say that the 4 most important things are:
-to drive them at 24VDC
-to mount them so that the head of the sensor is perpendicular to steel plate or whatever and body long wise in the same axis of movement
- shielded wire
- good quality flex wire not very thin, if budget permits same as stepper cable
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
Strengthing a steel gantry.
By gavztheouch in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-06-2014, 09:11 AM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
FOR SALE: For Sale : Gantry CNC Machine, Bedford
By pcstru in forum Items For SaleReplies: 1Last Post: 05-06-2011, 05:16 PM -
BUILD LOG: My flying gantry machine
By progomez in forum DIY Router Build LogsReplies: 29Last Post: 21-09-2009, 10:30 PM
