Thread: Aluminium Grades
Can't honestly answer the misting question as I have never done it, if the pump has enough pressure then it should mist given the right nozzle, think hosepipe but if it's low pressure then it may need a bit of a hand.
Then again a simple air spray system will mist, like a cheap spray gun.
Not sure about a car oil filter as a return system because on a car it's pumped. Someone would need to work out how long it takes to flow thru by gravity and is it backs up too much.
Sorry not been more helpful but as I say no experience.
[edit]
The professional misting systems work total loss but use very little liquid.Last edited by John S; 31-05-2009 at 01:59 PM. Reason: edit added.
John S -
BUILD LOG: Aluminium CNC log.
By jcb121 in forum DIY Router Build LogsReplies: 111Last Post: 04-04-2012, 01:37 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
RFQ: Aluminium sculpture to be CNC'ed
By dav in forum Projects, Jobs & RequestsReplies: 6Last Post: 07-01-2012, 04:37 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
