Thread: Aluminium Grades
31-05-2009 #13
Diesel injection pump isn't really suitable, the clearances inside required to get up to 115 bar to 280 bar - 1700 psi to 4,000 psi means the slightest lack of lubrication or grit and it's toast.
Going slightly off topic but whilst looking up these pressures which I had forgotten [ past life ] I found out that the latest diesel with high pressure common rail systems use pressures up to 2,000 Bar or 29,400 psi.
Home made water jet anyone ?John S -
BUILD LOG: Aluminium CNC log.
By jcb121 in forum DIY Router Build LogsReplies: 111Last Post: 04-04-2012, 01:37 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
RFQ: Aluminium sculpture to be CNC'ed
By dav in forum Projects, Jobs & RequestsReplies: 6Last Post: 07-01-2012, 04:37 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
