    Quote Originally Posted by jimbo_cnc View Post
    OK thanks.
    You are correct, I need single flute to get the chip load OK. They are a bit harder to find and more expensive than 2 flute it looks like.
    For 19mm MFC I think I need 22mm or 25mm cutting length? I have seen some 20mm length is that too short?
    6mm 1flute down spiral
    0.3mm chipload
    10k rpm
    = 3000mm/min feed
    = 3.1 m/s cutter speed
    Is that getting better. Now I've lost the cutter speed tables I saw earlier.
    What about a compression cutter to prevent chipping that melamine facing?
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    Isn't compression cutter just a different name for down spiral?
    Compression cutters have both up cut and down cut flute patterns.
  4. The Following User Says Thank You to Shinobiwan For This Useful Post:
  5. #4
    Ah right. I see a lot of them have mostly down flute and a small up flute, that explains how I got confused because people were talking about them pushing the work down.
    I've cut a few small pieces of MFC on my little 6040 using my standard manual tools, 1/4" with 2 straight flutes. They haven't damaged the melamine edge.
    I was hoping to use the same tool for cutting the 19mm edge and for grooves which are about 6mm deep. It looks like I might be lucky and that the melamine will still be on the down flute for grooving.
  6. #5
    You can ask 1000 people and they will all tell you a differant feed n speed, WHY.? . . . Because every machine is differant.
    No one tell you exact speed N feeds you'll get away with unless they have the exact same machine and even then material and tool grades play some part.
    They can only guide you to small degree based on machine spec which is what I did on the phone, the fact you have removed the machine spec makes this harder for folks to help. (And giving attitude when spec is questioned isn't endering)
    Now if it was the same you told me with single 32mm ballscrew using steppers then 3500mm/min will be close to rapid speeds which is differant to what you'll get cutting making things worse. Hence why I told you it would be too slow for cutting MFC or MDF and maintain any decent tool life. The spec you told me was IME mixed up and wrong for any decent machine for cutting wood.
    By your own searching you can see that average feeds are much higher so what do you want to hear.? . . Best advise in the world isn't worth a cracker if it's ignored, like wise all the sweet words you'd like to hear don't mean a thing if there wrong. They won't make the machine any better suited.!!
  7. #6
    As I've said, I'm trying to get away with a slower machine than what is recommended for tool life and productivity. And I'm hoping I can because my requirements are very different to a cnc shop.
    And I wanted this thread to be about minimal requirements for a machine, not about any particular machine I'm looking at.
    I'd be happy to hear about what machine design WILL fit my needs though, if anyone wants to make suggestions.
    I've got another thread about designing a machine, it's still at the stage of choosing steel frame or aluminium extrusion. I got a bit hung up with straightness of rails I think after reading all Sylvaskis epoxy endeavours. So it hasn't got on to drive system yet.
  8. #7
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    Forgetting about tool life and cut quality for a minute.
    3500mm/min is painfully slow, and will get old very quickly. Imo, there's really no excuse for a machine to be designed to have a maximum speed of 3.5m/min.
    Now, yes, you can cut at 3m/min with a 2 flute cutter, at 10,000-12,000 rpm, and get good results.
    Fwiw, I cut 19mm melamine at about 25m/min every day - on a $100,000 machine.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  9. #8
    It was my mistake to originallly say I only needed a slow machine, that's why I was offered 3500mm/min. When I know what speed I need (not what I want!) I can get a faster spec.
    OK, here's the machine (1500mm version).
    http://www.alibaba.com/product-detai...981060776.html
    The advert for the 1500mm bed machine states up to 8000mm/min working speed. Seller has said 6000mm/min is fine, maybe 7000 for my machine. But as Jazz noted, seller has suggested it will mean going up to 32mm ballscrew.
    I'm having a 3kW spindle and square rails at the moment.
    edit:
    I've forgotten one of my principles: always think about resale value. So an abnormally slow machine doesn't make sense there.
    So, I will up the speed to 6000 ish. I need to understand the performance disadvantages of 32mm ballscrew, in case seller offers eg only 5000mm/min with 25mm screw, or 6500 with 32mm.
    I guess I'm going to have to download octave unless there's an excel spreadsheet calculator around?
  1. RFQ: Wood CNC routing service (wood Letters)
    By coujin in forum Projects, Jobs & Requests
    Last Post: 16-02-2015, 03:35 PM
  2. Hourly rates
    By newtoid1986 in forum Marketplace Discussion
    Last Post: 28-03-2014, 12:28 AM
  3. RFQ: MDF Panels (+ More)
    By codytom in forum Projects, Jobs & Requests
    Last Post: 09-04-2013, 09:16 PM
  4. Looking urgently for a miller in Devon,r Exeter. Goods rates paid.
    By mwsufc in forum Opportunities Available & Sought
    Last Post: 04-02-2013, 10:42 AM
  5. Noob alert - 'Starter for 10' feed rates for MDF
    Last Post: 04-06-2009, 01:06 PM
