OK, so that was a bad thing for me to mention as a requirement to the supplier, I'm correcting that now.
I have some 6mm wide grooves, and 19mm wide grooves, both about 6mm deep. I was hoping to cut the whole thing with one cutter but swapping is no biggy either.
What do you recommend if I had 3kW spindle and 6000mm/min ?
The whole job with 6mm cutter and DOC= 6mm?
or 6mm cutter for narrow grooves, 10mm for wide grooves and multi-pass for cutting the profile?
Multipass rough cut the profile, then a full depth finish pass with compression cutter?
I will be hot glue edgebanding the cut edge, and I've got a choice of chipboard or mdf for the core of the melamine board.Last edited by jimbo_cnc; 05-03-2015 at 04:50 PM.
05-03-2015 #2
If you need both the top and bottom edges clean, then you want to cut the profile with a compression bit.
If you can, I'd try to go up to a 4-5Kw spindle, which should let you cut the profile in one pass with a 10mm compression bit. Machine rigidity will dictate how fast you can go, but I've cut 19mm board in one pass at ~17m/min with a 10mm compression bit.
If your limited to 3Kw, then I'd probably try using a 1/4" compression bit for everything. Cut the profiles slightly oversize in 3 passes, with a final cleanup pass at full depth, removing about .5mm.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
05-03-2015 #3
Thanks for that.
I'm not limited to anything. I'm just looking for the most economic way to cut 200 boards per year.
05-03-2015 #4
The most economical would probably be to pay someone else to cut them.
Gerry
05-03-2015 #5
It might be close if they were all the same, but say I have 10 model options. That would mean liasing and travelling to the cnc shop everytime someone orders one. That's $50 of my time IF it all goes well, plus the $100 machining fee x 50 visits = $7500 per year.
If I damage a panel later in the build process the costs and delay are horrendous if I can't just run another one off myself.
Obviously there are also many other advantages to having my own machine too, outside of the main 200 board requirement.
RFQ: Wood CNC routing service (wood Letters)
By coujin in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-02-2015, 03:35 PM -
Hourly rates
By newtoid1986 in forum Marketplace DiscussionReplies: 4Last Post: 28-03-2014, 12:28 AM -
RFQ: MDF Panels (+ More)
By codytom in forum Projects, Jobs & RequestsReplies: 6Last Post: 09-04-2013, 09:16 PM -
Looking urgently for a miller in Devon,r Exeter. Goods rates paid.
By mwsufc in forum Opportunities Available & SoughtReplies: 1Last Post: 04-02-2013, 10:42 AM -
Noob alert - 'Starter for 10' feed rates for MDF
By HankMcSpank in forum Machine DiscussionReplies: 6Last Post: 04-06-2009, 01:06 PM
