02-06-2009 #11
One think I noticed with those is they are 4 flute, now 4 flute can be centre cutting or can't depending on how they are ground.
The ad doesn't say centre cutting so it's anyones guess, if one flute doesn't cross over centre then they won't plunge cut.
Can you post after you have received them ?John S -
WANTED: 3mm Ball nose bit please
By Fivetide in forum Items WantedReplies: 6Last Post: 12-12-2012, 05:06 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
WANTED: ER20/25 straight shank collet chucks
By m_c in forum Items WantedReplies: 4Last Post: 24-10-2011, 12:19 PM -
Leitz Router Bit, Odd Shank Size?
By gazza in forum Tool & Tooling TechnologyReplies: 4Last Post: 27-02-2011, 03:26 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
