Just out of interest... what type of router are end mills with 4mm shafts used with?
I'm figuring those routers with 1/4" capability, but with a collet to shrink it down a litt?
As it goes I do have a larger 1/4" router (but it makes way too much noise)...I shall probably hang onto them for after when I get my acoustic shroud built!
07-06-2009 #2
Hank,
It's the way things are changing, all the old engineering books like Chapman etc are totally out of date as regards tooling. For one thing what we knew as cutter descriptions have changed out of all context and even the manufacturers come up with their own descriptions.
At one time we had slot drills and end mills, slot drills are two flute with one flute going over centre so it can plunge and hey ho cut a slot.
Ends mills were 4 flute and had a hole in the centre for the grinding wheel to run out into and for that reason they couldn't plunge cut, you had to start off the work and move in hey ho hence 'end' of the work.
However modern CNC grinding techniques mean we can get 2, 3, 4, 5 or even 6 flute with or without centre cutting. Confused :question: well you will be.
The manufacturers haven't helped in that they call some cutters 4 flute end mills but they can plunge cut and on the same page they call a similar cutter a 4 flute slot drill.
So basically they have thrown the book out the window and it's a free for all. The old standards and terminology have gone forever. Don't believe me look in J&L book, or Cromwell, or WNT
Now the next bit is shanks, we had 4 sizes in metric and imperial.
6,10, 12 and 16 or 1/4", 3/8", 1/2" and 5/8" with 1/8" or 3mm for the tiny sub spindles. Many were threaded to fit the Clarkson type chucks.
With the advent of Carbide it was harder to grind the thread and the Clarkson fell out of favour for the straight collet chucks such as the ER series.
Because the ER series has no gaps in the range unlike a 1/2" Clarkson which can only hold 1/2" it then became viable to make the cutter size out of the blank size so we get things like a 7mm cutter ground from a piece of 7mm stock, add to this it can have 2, 3 or 4 flutes and still be centre cutting and you can see how we have moved on.
Hope that answers your question.
.John S -
28-07-2009 #3
And I thought that would clear up the confusion. lol
I understood Dremels to have 1/8" 3/32" and 1/16" collets in their metric equivalents 3.2mm 2.4mm & 1.6mm. Their collets are very difficult to align. As too their 3 pin mini chuck.
I have limited experience of Routers; the ones I have, have 1/4" & 8mm collets. My friend bought an AEG one last week which had a range of collets from 1/2" down to 6mm, I didn't get to see what other sizes were in the box before he magiced it away.
My first Dremel died after a long life and rather than recycle it at the community depot, I stripped the rotor out of it, removed the fan, cut the shaft just below the rotor windings, and had it ground down to fit the 8mm collet of my B&Q el cheapo router. So with that in place I get to use all my Dremel bits.
To answer the question posed in the thread title? I suggest a 1/16" ball end mill cutter. Perfect for fine detail carving in wood featured in Vcarve.
JohnTemplecorran
Where the Light was kept during the Dark Ages
WANTED: 3mm Ball nose bit please
By Fivetide in forum Items WantedReplies: 6Last Post: 12-12-2012, 05:06 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
WANTED: ER20/25 straight shank collet chucks
By m_c in forum Items WantedReplies: 4Last Post: 24-10-2011, 12:19 PM -
Leitz Router Bit, Odd Shank Size?
By gazza in forum Tool & Tooling TechnologyReplies: 4Last Post: 27-02-2011, 03:26 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
