  1. #10
    Yes, google translate is spot on:)
    And thank you for all feedback. I really need feedback since this is my first CNC.
    The sand filled beams sounds nice. Problem is that I have so many holes to plug. The lower Xbeam has a total of 26 holes in it. 8 on each side to fasten it to the Zbeam and 10 for the linear bearing screws. I once had loudspeaker with sand filled stands and that worked really good.
    I'm a bit worried that the Z moving part becomes weak but that is a later problem.
    The electric cabinet could be as you say a bit noisy. Thank you. When I made it I figured the drivers had grounded houses and the "ring trafo" should not radiate that much magnetic fields. But I have the break out board unprotected and I don't know how sensible it is. I am able to fit a plate between the trafo and the drivers if I need. I planning on having shielded cables for the motors but the "on to the break out board cable" from the PC is unknown (cheap cable).
    Here is a short video clip of when I test ran the motors. The wantai driver seems to have plenty of power. Cheers!
    http://www.br-automation.com/downloa...MASMOT-ENG.pdf
ID:	14928   Click image for larger version.
ID:	14929   Click image for larger version.
  1. DIY CNC Milling Machine From Scratch
    By totts in forum DIY Mill Build Logs
    Last Post: 02-05-2019, 11:11 PM
  2. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  3. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  4. Building from Scratch or follow some plans?
    By Monk in forum Gantry/Router Machines & Building
    Last Post: 12-08-2010, 10:27 PM
  5. Need helpwiring up from scratch
    By GeorgeD in forum Machine Discussion
    Last Post: 13-07-2010, 06:23 PM
