    Looking good so far. You could use the machine to make reinforcement plates to brace the gantry (assume you don't have milling machine etc) as that profile is not as stiff as steel and it looks like you are using simple fasteners to hold it all together.
    Once you get the weight of the y and z axis fitted and the spindle give the gantry a thump with a soft hammer and you will feel it vibrate. just something to think about as you progress.
    Thank you,
    I plan to make 10mm aluminum plates on the sides to fasten the Xmotor and make it more rigid. I have some friends that are building another kind of machine and I can use the same side plates they are ordering from the vendor. A plate behind the X is also under consideration.
    Then I plan to reinforce the Y rods with a pair of brackets. Hopefully it will be firm enough.
    The bolts are ordinary M8 and M5 for the linear bearings. But there is allot of them.
    Next up is to choose what kind of ball screw Im going to use. Ill try the hammer
    I have started to plan how to measure and adjust the axis and I think I am able to get it fairly straight after a lot of adjustments. The frame is about 0.05 to 0.1 mm off before any adjusting. It might be different when I have all parts on the frame and tighten every thing up.
    The linear bearing had a little banana shape so I straightened the first one up by clamping it to a straight surface and tightened it so it is real straight. The other side I plan to fasten after the wagon is mounted so that it will follow the one I straightened. That was a strange sentence, I'm sorry for my English..
    I have also ordered three ebay 16mm diameter ball screws with bearings. Now the fun part begins
ID:	14847   Click image for larger version.
    That looks nice and tidy. Don't worry about your English, it is pretty good and I am sure that is a thousand times better than most forum members Swedish. G.
    Thank you Geoffrey. Its good practice and as long as I'm being understood I'm happy:) Min svenska är lite bättre dock ;)
    Quote Originally Posted by bofred View Post
    what he said........
    what ever that means
    looking good and keep the updates coming :)
    Min svenska är lite bättre dock - ‎My Swedish is a bit better though
    (thank you google translator!)
    Now I can see the side view of the gantry the lower gantry beam is actually supported underneath as well as at the rear - should be better than I originally thought from the first photo.
    Once you get the side plates added it will be a nice machine. But before you do I would add kiln dried sand to the gantry beams to add weight and provide damping. As this is a fixed gantry machine there is absolutely nothing to loose and it will help with the finish of the cut. Add one end plate, turn the machine on its side and fill to the top with sand, then add the second plate.
    On the electrical side - and I'm not an electronics expert so I might be worrying over nothing - is it good practise to put the stepper driver right over the top of the transformer coil (trafo in swedish)? Is there a risk of electrical interference?
  1. DIY CNC Milling Machine From Scratch
    By totts in forum DIY Mill Build Logs
    Last Post: 02-05-2019, 11:11 PM
  2. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  3. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  4. Building from Scratch or follow some plans?
    By Monk in forum Gantry/Router Machines & Building
    Last Post: 12-08-2010, 10:27 PM
  5. Need helpwiring up from scratch
    By GeorgeD in forum Machine Discussion
    Last Post: 13-07-2010, 06:23 PM
