Thread: usb - parallel
mornin, just a quicky folks, would a usb 2 parallel connector be ok for the job, would it work ok, or would you recommend a installing a parallel port card, TIA
12-03-2015 #2
12-03-2015 #3
to connect pc to break out board
12-03-2015 #4
there are a number of motion controller that do the conversion of the USB signals to something to plug in to the break out boards.
There is a very mixed reaction to using the generic USB to LPT adapters that can be bought in computer shops. I think it may be that they are primarily for printers and not for running CNC machines.
If you do not have a parallel port on your computer you should consider looking at a PCI card or even better a dedicated motion controller.
You may be thinking you can do it on the cheap but I found that you spend more time and money trying to make things work if you do not get a good solution.https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
12-03-2015 #5
Mach3 uses its own drivers for the printer port. The timings are critical and you can't emulate that with a USB -> Parallel converter. It won't work and you will just be wasting time and money.
The Following User Says Thank You to cropwell For This Useful Post:
breakout board usb or parallel
By crossleymarko in forum Motor Drivers & ControllersReplies: 13Last Post: 30-07-2013, 12:44 PM -
Steppers, Series, Parallel
By Ricardoco in forum Stepper & Servo MotorsReplies: 14Last Post: 12-01-2013, 08:28 PM -
Parallel PCI Card Experience
By andy0202 in forum Computer HardwareReplies: 11Last Post: 24-08-2012, 10:39 PM -
PCI parallel card / BOB
By artmin in forum Computer HardwareReplies: 11Last Post: 30-01-2012, 04:38 PM -
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
