Thread: usb - parallel
    mornin, just a quicky folks, would a usb 2 parallel connector be ok for the job, would it work ok, or would you recommend a installing a parallel port card, TIA
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 83 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by universally View Post
    For the job of what? You need a motion controller if you whant to use the usb or fit a pp card in the pc.
    to connect pc to break out board
    there are a number of motion controller that do the conversion of the USB signals to something to plug in to the break out boards.
    There is a very mixed reaction to using the generic USB to LPT adapters that can be bought in computer shops. I think it may be that they are primarily for printers and not for running CNC machines.
    If you do not have a parallel port on your computer you should consider looking at a PCI card or even better a dedicated motion controller.
    You may be thinking you can do it on the cheap but I found that you spend more time and money trying to make things work if you do not get a good solution.
    https://emvioeng.com
  5. The Following User Says Thank You to komatias For This Useful Post:
  6. #5
    Mach3 uses its own drivers for the printer port. The timings are critical and you can't emulate that with a USB -> Parallel converter. It won't work and you will just be wasting time and money.
  7. The Following User Says Thank You to cropwell For This Useful Post:
  1. breakout board usb or parallel
    By crossleymarko in forum Motor Drivers & Controllers
    Last Post: 30-07-2013, 12:44 PM
  2. Steppers, Series, Parallel
    By Ricardoco in forum Stepper & Servo Motors
    Last Post: 12-01-2013, 08:28 PM
  3. Parallel PCI Card Experience
    By andy0202 in forum Computer Hardware
    Last Post: 24-08-2012, 10:39 PM
  4. PCI parallel card / BOB
    By artmin in forum Computer Hardware
    Last Post: 30-01-2012, 04:38 PM
  5. Which USB parallel port emulator is the best
    By bruce_miranda in forum General Electronics
    Last Post: 18-09-2008, 03:38 PM
