Thread: Machining thin Balsa
04-04-2015 #1
Afnoon all.... I have a challenge from a customer where I will need to machine some Balsa wood which is 3mm thick.
Small heart shapes, not many around 20 but are there any "Gotchas" I need to be aware of /
Currently using LH 2mm 2 flute cutters at 18000rpm and around 1200mm min... Toofast or what ?
RobIf you can't fix it with a hammer you've got an electrical problem !
05-04-2015 #2
Long time since I did balsa ( prefer liteply) but biggest problem was furry edges / slightly ripped edges which needed cleaning up
05-04-2015 #3
You could always lasercut it :)
05-04-2015 #4If you can't fix it with a hammer you've got an electrical problem !
EXPERIENCE: machining service
By D-man in forum Trading Experience & FeedbackReplies: 0Last Post: 25-10-2014, 08:21 PM -
Plastics for machining?
By Washout in forum Machine DiscussionReplies: 0Last Post: 22-04-2014, 11:27 AM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
Step clamp design - Hold down thin or irregular shaped objects while milling!
By Lee Roberts in forum Programmers CornerReplies: 5Last Post: 15-04-2012, 12:36 PM -
Looking for thin plastic? sheet
By irving2008 in forum Machine DiscussionReplies: 19Last Post: 09-09-2010, 12:32 AM
