    Hi, I'm bench testing my motors - they are all wired up correctly and I can get them to turn when I run the roadrunner code in mach3, so I assume all connections are good. I am using this kit from cnc4you.co.uk http://www.cnc4you.co.uk/CNC-Kits/Di...3.1Nm-x-3-Axis
    Problem is I have no idea what settings I should be using. The motors seem to be turning very slowly. I have set up in mm's and in the motor tuning section I can change the velocity etc but I havent got a clue what I should be setting things at - I wonder if somebody could suggest some settings as a starting point? Seems the max mm's per minute I can set is 700 - even at that the motors dont spin fast to be honest - even at that speed a full 360 degree revolution of the spindle takes approx 3 seconds which doesn't seem right even to a newbie like me. I dont know what to set the "steps per" or "step pulse" etc under motor tunings too. I think also maybe I should be setting the switches on the driver - details are all below
    Quick stats:
    PSU outputs at 36v
    motors Nema 23 3.1nm / 60BYGH301B
    Driver CWD556 digital driver - switch setting chart below
    Instructions that came with the kit show the settings for getting the motors to work ports and pins/ motor outputs and input signals and I have followed them to the letter - but there's no word on setting up anything else.
    Any help much appreciated.
Name:	Screen Shot 2015-03-13 at 12.19.31.png
ID:	14858   Click image for larger version.
Name:	Screen Shot 2015-03-13 at 12.28.25.png
ID:	14859   Click image for larger version.
Name:	Screen Shot 2015-03-13 at 12.29.18.png
ID:	14860   Click image for larger version.
Name:	Screen Shot 2015-03-13 at 12.29.58.png
  1. Random G-code for testing motor tuning.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 30-10-2019, 08:22 AM
  2. Plasma tuning speed...
    Last Post: 12-02-2014, 10:45 AM
  3. Help withController dip switch settings and Mach3 motor tuning
    By liamo1991 in forum Motor Drivers & Controllers
    Last Post: 15-11-2013, 02:22 AM
  4. Help please with motor tuning mach 3.
    By Kevin1970 in forum Artsoft Mach (3 & 4)
    Last Post: 13-06-2012, 10:22 PM
