  1. #14
    Quote Originally Posted by tropostudio View Post
    What about making the belt on the drive motor side a continuous loop (tank tread) and skipping the full length top belt? If you mount the belt system upside down, similar to how you see racks mounted on many CNC router axes, the protection from dust or chips seems unmerited.
    Regards,
    Chris Krumm
    Have been planning a moving table router and wanted to try a Servobelt design. I had some Vexta 5 phase motors with 10-1 low backlash gearboxes which I wanted to use. Wanted a sort of modular self contained drive that I could bolt onto the frame, I shall be using a dual drive and will sync the drives with a shaft between the motors.
    The std. 37mm OD bearings are assembled on steel tubes for alignment, they act as spacers for the side frames and are clamped together by the mounting bolts
    The engagement with the belt on the table, is set by the outer bolts in the chassis having slotted holes in the frame. The belt tension is set by moving the motor in the slotted holes in the chassis plates, also carries an outrigger bearing for the 18 tooth pinion.
    I have carved a setup out of wood before I waste any aluminum
ID:	15885   Click image for larger version.
ID:	15886   Click image for larger version.
ID:	15887   Click image for larger version.
ID:	15888   Click image for larger version.
ID:	15889   Click image for larger version.
  1. Which Belt Profile
    By manofgresley in forum Belt Drive, Pulleys & Timing
    Last Post: 27-09-2013, 12:54 PM
  2. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  3. Belt Driving your leadscrews !
    By Lee Roberts in forum Lead Screws, Nuts & Supports
    Last Post: 05-02-2011, 09:14 AM
