Thread: new member
Well the first 2 lines says it all....TB6560 (by the way you're brave running it at 36V, surprised you've not had the magic smoke from it yet at!!!!) and Nema34 motors.
See this thread...http://www.mycncuk.com/threads/1373-...ghlight=TB6560
You're never going to get any sort of performance running Nema 34's with a TB6560. Nema 34's need 100V plus to get any sort of performance.....Last edited by njhussey; 20-03-2015 at 12:21 PM.
20-03-2015 #2
Im confused, you say im not going to get any type of performance out of the 34's because they need 100v however they are not rated that high voltage and all but "Z" was working fine.
The upgrades consist of new limit switches/E-stop, rewire from 22 gauge to 16 gauge on the stepper motors, and new connectors between the two modules, what i call the brains (computer and breakout circuit (software)) and the working module (Stepper motors X Y Z and limit switches (hardware)).
20-03-2015 #3
The rated voltage is much lower than the voltage you can actually drive them at using pulses (ie what the stepper driver voltage is)
I'm afraid Neil is correct and you have built a mismatched system. 36V is way too low for Nema34. You can either accept that or wait for someone to post the technical reasons why.
You are also running lead screws not ballscrew and have anti backlash. This all adds to the friction when lifting the Z axis. To add to it further they are on skate bearings although that should be a minor factor in terms of allowing a smooth lift.
The cheapest way to stop loosing steps would be to swap out the Nema34 on the Z to a Nema23, and probably turn the voltage down a touch to be kind on the chips. Keep the acceleration and velocity at modest levels and you should avoid loosing steps.
If your leadscrew pitch is 1" per turn then I think you would also benefit from a 2:1 pulley on the ZLast edited by routercnc; 21-03-2015 at 05:36 PM.
21-03-2015 #4
If i wait for someone to post the technical reasons, I probably wouldn't understand the post anyway.
I will go with the Nema 24 on the Z. for now.
Could you expand your thoughts on the pulley? Are there any pics of this system?
If i continue using Neman 34 (thinking about expansion) what would you recommend?
21-03-2015 #5
Just noticed that I've typed Nema 24 where I should have said Nema 23 on my posts - corrected. I should also add that you need the lower inductance ones -I'm away from my computer but remember somewhere around 2-3 mH being a good choice. Hopefully someone can post up a good spec.
If you look through the build logs here you should see some of them using pulleys. Your screw pitch is very high putting a lot of load on the motor so the pulley ratio will give the motor more torque with less chance of stalling
If you want to stick with the 34s then you need to buy 4 separate stepper drivers and a break out board. This will be a lot more expensive than your current board and it's all because of your choice of motors which are a bit big for the machine you describe.
When I'm back at my computer I'll try to find the ones most people use. I think Kinko do some mains powered ones which will really make the best use of them.
This thread talks about using 34s
http://www.mycncuk.com/archive/index.php/t-8248.htmlLast edited by routercnc; 21-03-2015 at 05:43 PM.
21-03-2015 #6
I'll give it in simple Technical terms. Large motors have more Inductance or think of it as Resistance to flow of current thru it's windings and Current gives us Torque.
Then think of voltage as the force pushing current thru the motor windings.
So with higher inductance you need more Push to achieve the same speed as motor with lower Inductance. Then because torque mostly comes from current and your struggling to Push the current thru the windings then Torque is also lower.
Think of it as trying to drive a manual gearbox(don't think you have many of these in US . .Lol) Car Slow in too high gear!! Because your speed isn't enough then Motor stalls.
Now you have the worst mix match of components because Nema 34 motors have high inductance but you have Low voltage. Made worse by Drive/s that don't allow higher voltage and like has been said your very lucky you haven't fried them already running so close to there Max voltage.
Unfortunatly it gets worse when it comes to speed because you have high friction linear components in the form of Lead screw and Skate bearings.
This translates into Driving Car Slowly in high gear with the brakes Sticking and the end result motor stalls at lower speed.!!
25-03-2015 #7
So my take on this is:
get a Nema 23 stepper motor to go on the Z axis and use what I have
or
get a larger power supply and stepper motor controllers?
The largest motor controllers I have found are 80v. Will they do?
25-03-2015 #8
Well it's a close call really. .? . . . . Nema 23 motors are cheap and if you combine these with 2:1 ratio using pulleys then they will probably do the job with 36V. . . . Think personally in your position I would so go for this option as it's cheapest and easy.
If it doesn't work then I would say Start again with new drives, Nema 23 motors and PSU that match better and sell your existing stuff.
