Thread: new member
05-05-2015 #27
For some reason the thank you message did not go through so here it is - Thank You for that information. You have explained it well. The next problem I am having is setting up Mach3 Ports and Pins "Motor Outputs". The simplest way to ask this question is: Is there a way to determine which pin is motor and which pin is direction for each motor? What is printed on the breakout board is as follows:
Pin Label
2 Dir + X
3 Dir - X
4 Dir + Y
5 Dir - Y
6 Dir + Z
7 Dir - Z
I have assumed the "+" is the "Step Pin#" and the "-" is the "Dir Pin#".
(again Thank You All for listening to the ramblings of this old man)
