Page 3 of 6 FirstFirst 12345 ... LastLast
  1. #21
    Oddly odd. If I get a chance I will check mine tonight and see what happens but I have a different cpu card from you. Might be best to email Bert and see what he says.
  2. #22
    D-man's Avatar
    Lives in Newcastle, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 645. Received thanks 7 times, giving thanks to others 54 times.
    I will do that thanks. I had pondered on reinstalling the software so it was fresh incase something had happened in the download. Suppose it couldn't hurt
  3. #23
    Like you say it woudnt hurt. Just make sure that the install drivers bit completes after the program install. I think it does need all its own stuff to work correctly. You could also try inverting the amp enable output just to see what happens.
  4. #24
    Just tried mine and it does turn off the drives and also the tick in the I/O screen for enable goes off. I am using V4.01 of the software.
    Probably best to email Bert and see what he says.
  5. #25
    D-man's Avatar
    Ah I'm using 4.02. Wonder if I should use that version for now
  6. #26
    It would be worth a try even if its just to see what happens. One thing I did notice was that after turning the drives off the button wont turn them back on. You have to press reset but that might be built into the software.
  7. #27
    D-man's Avatar
    Yeah same on this version too
  8. #28
    Have a go with V4.01. You don't have to uninstall the version you have.
  9. #29
    D-man's Avatar
    Yeah I will pal,just finishing off some method statements for my company, worst job ever!
  10. #30
    D-man's Avatar
    OK, version 4.01 still acts the same... couple questions if you don't mind?
    1. The light on the board - When the drives are enabled is this light supposed to stay on?
    2. The 5V to enable the drives - which inputs are these to go into? i originally had the in 16 and GND and it works but motors would still stay engaged if i disabled the motors with the software.
    Sorry - the IO screen that button does stay checked. I got mixed up, its actually the amp enable that will not stay checked.
    I have also soldered the bottom of the board as asked
  1. Eding CPU5A4E controller and Siemens G110 VFD.
    By calgone in forum EdingCNC (CPU5, CPU5A)
    Last Post: 06-02-2015, 11:31 PM
  2. FOR SALE: Various Steppers, servos, drives for sale
    By Peter. in forum Items For Sale
    Last Post: 02-02-2014, 09:56 PM
  3. Big single phase servos and drivers
    Last Post: 04-09-2013, 01:18 AM
  4. Open Source Servos
    By D.C. in forum Open Source Designs & Plans
    Last Post: 07-03-2013, 07:29 PM
  5. Mariss Freimanis Steppers vs Servos Advantages/Disadvantages of both
    By Lee Roberts in forum Stepper & Servo Motors
    Last Post: 02-10-2007, 09:08 AM
