18-03-2015 #8
Ok well first the Servo drives are dealing with the encoders closing the loop at the drives and all your doing is sending it Step & Dir signals(pulses).
I did make a mistake when I said you'd get +68 M/min because I forgot about the ratio so RPM would be 625rpm at the pinion giving Max Velocity of 34.5 x 625 = 21.5M/min Rapids. . . BUT that would be with full 2000 rpm from motors which you won't get if 125Khz frequency. You'll only get 750(rpm) /3.2(ratio) = 234(rpm) x 34.5(pitch)=8085mm/min.
So really your wasting plenty of the motors potential and machine rapid speeds.
Why those figure didn't work I think can only be because your ratio is not what you think it is.?
Eding CPU5A4E controller and Siemens G110 VFD.
By calgone in forum EdingCNC (CPU5, CPU5A)Replies: 4Last Post: 06-02-2015, 11:31 PM -
FOR SALE: Various Steppers, servos, drives for sale
By Peter. in forum Items For SaleReplies: 2Last Post: 02-02-2014, 09:56 PM -
Big single phase servos and drivers
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 04-09-2013, 01:18 AM -
Open Source Servos
By D.C. in forum Open Source Designs & PlansReplies: 0Last Post: 07-03-2013, 07:29 PM -
Mariss Freimanis Steppers vs Servos Advantages/Disadvantages of both
By Lee Roberts in forum Stepper & Servo MotorsReplies: 0Last Post: 02-10-2007, 09:08 AM
