Yes they appear to switch off. If you are using a relay powered from the watchdog to switch the enable signal you can measure the voltage to the coil or see the coil switch. Looks like the info on the cpu says that the watchdog is green for ok and red for not so I presume that green is output signal and red no output signal. Can you check the voltage to the relay and see if it switches?
