    The question to ask is if you would like to have CAM capability on the same PC running your motion control. If so then stick with Mach3 and a motion controller. Mach3 becomes a joy to use when you are confident that you machine is not losing steps and communication.
    This is mine before I had converted the quill too:
    https://emvioeng.com
    If Mach is not working for you then it's not Mach's fault because it's Proven by 10,000's of users rangeing from plotters to very large powerful mills and lathes that it work perfectly well when correctly setup and left unattended for hours on end..!! . . . . Like Hoods Spidery beast.
    I am a lover of linuxcnc. Using either the printer port or other external interface cards - Rock solid. Any bugs that are found are fixed pretty darn fast. Pair Linuxcnc with mesa hardware (very inexpensive) and you have an industrial grade control.
    Current released version change log
    http://wiki.linuxcnc.org/cgi-bin/wiki.pl?Released_2.6.X
    Next release version change log (you can test it now if you want) 2 exciting additions - support for mesa Ethernet connected interface boards and the new trajectory planner. (unknown at the time that it was funded by tormach and given back to the community) - Tormach used linuxcnc for their new control.
    http://wiki.linuxcnc.org/cgi-bin/wiki.pl?Released_2.7.X
    I have used mesa hardware in my systems and have found it to 'just work'. The owner is also very active in the linuxcnc community.
    Linux isn't as scary as others would like you to believe. You do not have to be a 'programmer' to use linuxcnc. Between linucnc's HAL layer and its integrated ladder logic - pretty much anything is possible without writing a line of code. (although you can if you want to.. There is a C like language that allows you to write realtime components for your system - not to mention you have access to the source code) most people only scratch the surface.
    sam
    Welcome to the forum Sam I use Linux on my mill and lathe and Mach3 on the router The one problem I can see with Linux when using slaved axis (joints) with a router is the homing Linuxcnc as of this time has never got this sorted yet.
    So we can throw all the Linux questions your way ..Clive
    Yes - I can field questions or at least point you in the right direction.
    Ugh - Slaved axis.. I have not had a machine that has used slaved axis. I know there are atleast 5 different ways to set it up. Strictly hal, gantry kins, other ways I can't think of.. It is doable but the setup hasn't really been standardized. Plus I know there is some development work that hopes to standardize the setup. (not to mention the joint/axis work also.)
    Looks like you asked here :)
    http://www.linuxcnc.org/index.php/en...ate-slave-axis
    Like was mentioned there are a couple of gantry configs in linuxcnc to check out.
    some other examples..
    http://wiki.linuxcnc.org/cgi-bin/wik...yPlasmaMachine
    https://www.google.com/search?q=slav...utf-8&oe=utf-8
    http://linuxcnc.org/index.php/englis...gantry-machine
    random google search
    https://www.google.com/search?q=slav...oming+linuxcnc
    Like I say - many people do it - it just seems like eveyone does it their own way.. I hope there is a better standard in the future..
    sam
    Hi Sam,
    Thanks for the info, I've toyed with the idea of linux in the past, but only got as far as loading the demo operating system off a disk. Other than that I have no idea about it. I've seen other people using the mesa cards and they certainly are cheap for what you get. What combination of card and daughterboard would you recommend?
    Say if I were to set up linux for the first time without any previous experience and little to no programming experience, how quickly could I have stuff moving around? I'd like to build a custom control panel with MPG FRO and spindle speed over ride etc, are these easy to implement in linux cnc?
    You've got me thinking now.... I'm also finishing off a router at the same time, so if I could crack linux on my mill then I'd use it for that also
    Thanks,
    Adam.
    what is your hardware now? analog servos? Step/dir? Mesa has a 5i25 or 6i25 (pci or pci-e) that right out of the box acts like 2 printer ports on steroids. (so you could use your existing bobs if you are using printer ports) On steriod - I mean it does hardware (high speed) step/gen, pwm gen, encoder counting, and i/o. ie - well into the mhz..
    if you need more i/o than 2 printer ports - you can get daughter boards like the 7i76 that is a stepper interface. (gives you 5 axis step/dir output, analog spindle output, 48 i/o, spindle encoder input - and still expandable)
    you can buy it as a kit..
    http://store.mesanet.com/index.php?r...product_id=215
    linuxcnc has a configuration utillity for mesa hardware - I have never used it but it is constantly being improved.
    http://linuxcnc.org/docs/2.6/html/config/pncconf.html
    main docs
    do some reading....
    sam
    Quote Originally Posted by drumsticksplinter View Post
    Hi Sam,
    Thanks,
    Adam.
    drumsticksplinter ] You can also buy them here in Europe http://eusurplus.com/index.php?route...tegory&path=63.
    Sam I would like to ask you some questions re threading with G76 could I do it with email to you. ...Clive
    Thanks Clive, I was looking for other sellers of the mesa boards.
    I know that mach 3 has a large following and many people use it successfully all day everyday including myself. However, in my experience you can get mach to work quite well very quickly, but I don't have a great deal of faith in it in an industrial environment, probably because it was never intended for that purpose, hence the promise of a mach 4 industrial version. I like the look of mach 4, but don't believe its quite ready yet.
    Don't get me wrong, there are some amazing machines using mach such as Hood's and many others and I'm almost tempted to get hold of a smooth stepper and jump right in, but in the back of my mind I know I'll be disappointed. Has anyone got any experience of an MPG that works well in mach 3? when I've tested it it was horrendous to use and wouldn't trust it at all!
  1. Bridgeport VMC with Heidenhain control-
    By vargai in forum Gantry/Router Machines & Building
    Last Post: 13-01-2015, 02:37 PM
  2. Bridgeport with crusader i control
    By daff in forum Bridgeport Milling Machines
    Last Post: 10-09-2014, 09:04 PM
  3. CNC Motion control
    By StoneyCNC in forum Manufacturer News
    Last Post: 26-08-2013, 10:07 AM
  4. Time for a purpose built motion control computer.
    By GeoffV in forum General Computing
    Last Post: 08-11-2010, 01:11 AM
  5. Motion Control drivers and motors
    By bruce_miranda in forum Motor Drivers & Controllers
    Last Post: 27-08-2009, 09:40 AM
