I think you misunderstand, I'm not expecting the parallel port and mach3 configuration to be industrial strength because it obviously isn't. Conveniently though using a breakout board and parallel port provides a very quick and cheap means of testing the bare bones of a machine build and thats all I'd use it for.
I'm just looking for a good stable solution to a motion control system on my machine. The thing that has really put me off mach3 is the MPG feature, which is what i really want to work well, I've tested it with a pokeys board, which claimed to offer the feature, but the results were terrible. I've read about other people having serious issues with the MPG feature in mach3 too. No matter how much I ask about the functionality of mach3 with and MPG, nobody seems to be forthcoming with information, why is that? Because it doesn't work? Artsoft have said as much, thats why part of their selling point for mach 4 is "Higher quality manual pulse generator (MPG) = very smooth jogging and positioning without lag time.".
I was wondering if the MPG feature worked well with the ESS or CSlabs?
28-03-2015 #2https://emvioeng.com
28-03-2015 #3
28-03-2015 #4
I am very happy with jog performance in linuxcnc. On the k&t I use it all the time for setting parts/tools. (I use a 1/2 dowel pin and jog wheel for setting zero - rolling it between the part and tool)
http://linuxcnc.org/docs/html/examples/mpg.html
There are a bunch of ways to hook a physical jog encoder up. The above example is similar to how I have implemented it on my machines. That example is also a real time jog implementation.
28-03-2015 #5Thanks for all your input regarding Linuxcnc, I have decided to take the plunge and have ordered the mesa 5i25 and 7i76 kit, which should arrive to me next week sometime. I was really impressed with your machine setup, some complex stuff going on there for the toolchanger to work so well ;) Thanks also for the info on the MPG setup, the code doesn't mean a whole lot to me at the minute, but I'm sure I'll get my head around it!I am very happy with jog performance in linuxcnc. On the k&t I use it all the time for setting parts/tools. (I use a 1/2 dowel pin and jog wheel for setting zero - rolling it between the part and tool)
I'm going to ditch out the windows install on my bridgeport pc and load up linux asap. I've been afraid of trying linuxcnc for a while and I'm sure I'm not the only 1 who'd consider it to be a move over to the darkside, but hey! it might turn out to be the best thing I've done
Its all still very daunting and I'm sure there is a learning curve, but from what I'm reading this seems the right decision for my machine at this time. I know there is always a linux vs mach3 battle going on as with the Windows vs Apple. I use a Mac 90% of the time btw
28-03-2015 #6
Can't speak for any other MPG on Mach but these but Cslabs MPG Module works perfectly.!
Pokeys is a toy in comparison to real motion control but to be fair I've setup a MPG with Pokeys and didn't have any issues. Thou in fairness I didn't push it or look for any issues and it was just a small lathe.Last edited by JAZZCNC; 28-03-2015 at 04:16 PM.
28-03-2015 #7
Thanks for sharing your experiences with the MPG feature and the motion controllers. I really liked the look of the cslabs stuff and the add on modules seems like a nice feature. I was a bit reluctant to pay the price for the IP-S at this stage though and the IP-M won't do exactly what I require.
Bridgeport VMC with Heidenhain control-
By vargai in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-01-2015, 02:37 PM -
Bridgeport with crusader i control
By daff in forum Bridgeport Milling MachinesReplies: 0Last Post: 10-09-2014, 09:04 PM -
CNC Motion control
By StoneyCNC in forum Manufacturer NewsReplies: 1Last Post: 26-08-2013, 10:07 AM -
Time for a purpose built motion control computer.
By GeoffV in forum General ComputingReplies: 17Last Post: 08-11-2010, 01:11 AM -
Motion Control drivers and motors
By bruce_miranda in forum Motor Drivers & ControllersReplies: 71Last Post: 27-08-2009, 09:40 AM
