Thread: Smoked a contactor , but why?
Hi
When you have the correct contactor (24 volt dc) you need to put +24 volt onto terminal 13 of the PNOZ X1 then out on pin 14 this then goes to to A1 on your contactor and A2 to your zero volts so when your safety relay is reset this will then pull in the contactor. When you press the e stop this will then drop the contactor out.
AndyLast edited by audioandy; 27-03-2015 at 07:11 PM.
27-03-2015 #2
Hey Up Stranger!!! . . . Andy he does have it drawn that way but I see A2 (0v) on the contactor is connected to 24V which is wrong is that what your meaning.?
27-03-2015 #3
Hey up Dean
The way he has it drawn is +24v terminal 13 terminal 14 to A1 then terminal A2 back to +24V ?
I have to keep my hand in, might not post a lot but lurking in the background keeping an eye on you ; )
27-03-2015 #4
retrofit Boxford vmc mill 260 Info needed on Yaskawa contactor relay and VFD choices
By Roboteernat in forum Boxford Vertical MillsReplies: 10Last Post: 13-03-2015, 12:25 PM -
FOR SALE: Gerber System 48+ Main Contactor
By peter potts in forum Items For SaleReplies: 1Last Post: 10-03-2015, 12:01 AM -
Relay V Contactor
By GTJim in forum General ElectronicsReplies: 9Last Post: 18-03-2014, 10:10 AM -
Contactor sizing?
By Swarfing in forum General ElectronicsReplies: 5Last Post: 27-12-2010, 08:58 PM
