Done some research and will start to collect parts for my AMA25LV conversion.
For X and Y will use 5mm pitch 16mm ballscrew driven direct from Stepers Nema 24 4Nm
https://tinyurl.com/yyg2v3rk - hard to find get those Nema 24 with 4Nm
For Z will be 20mm ballscrew (double nut) 5mm pitch and Nema 34 - not sure what torque yet 8-10Nm (will use counter weight, 2spindle R8 and 2.2kw wet)
https://tinyurl.com/create.php 8.5Nm
Wonder if hybrid motor with close loop is not overkill?
Here is open loop version:
https://tinyurl.com/y53kcevf - Nema 24 X-Y
https://tinyurl.com/y5rcpmx9
https://tinyurl.com/y5zt582y - Nema 34 Z
Any advice kindly appreciatedLast edited by Tom J; 20-01-2021 at 08:14 PM.
10-04-2021 #2
The motors look fine. I have almost identical on mine. However.
I had to run my nema24's on 60vdc and my nema34 is a bit junk on 60v and is crying out for at least 80vdc.
Bear that in mind when looking at drivers and power.
Personally. I would get drivers that can run on ac power and use toroidal supplies.
That's the route I'm going next (that's if I decide to change to a closed loop system).
Daz.
AMA25LV CNC Project !!!
By Onocyclone in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 27-09-2014, 08:21 PM -
AMA25lv clones
By Onocyclone in forum Machine DiscussionReplies: 0Last Post: 06-09-2014, 05:20 PM -
NEW MEMBER: complete beginner saying hi
By helder1977 in forum New Member IntroductionsReplies: 6Last Post: 06-04-2013, 11:41 PM -
NEW MEMBER: complete newbie here :)
By chudds in forum New Member IntroductionsReplies: 0Last Post: 18-05-2012, 08:37 PM -
Complete conversion kits?
By leitzscope in forum General DiscussionReplies: 3Last Post: 01-05-2010, 07:57 PM
