Well depends on your lathe and your abilty's really. You'll need Collet chuck to hold the screws as 3 or 4 jaw won't be good enough. How hard depends on the screw quality. Often chinese screws are only case hardened and not very deep so can be turned with correct tooling.
Better quality screws are hardened deeper. Often the ends are ground not turned on harder quality screws, I know for sure Zapp grind not turn.
How you fasten the ends will depend on the conversion but in all cases at least one end will be "fixed" and use 2 x angular contact bearings fixed in a ridged housing of some kind to stop the screw floating. Often with mill screws being short then only one end of screw is fastened the "fixed" end and other end is left unsupported.
On longer length screws you would support both ends with bearings but only one end is Fixed and the other bearing free to float in it's housing to allow for expansion.
Really regards length and what exactly is required no one except someone who's done the exact same machine can tell you and even then I wouldn't trust without checking your own machine as castings etc change and often clearences, esp around the ballnuts are tight so best working from your own measurements.Last edited by JAZZCNC; 05-04-2015 at 02:08 PM.
AMA25LV CNC Project !!!
By Onocyclone in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 27-09-2014, 08:21 PM -
AMA25lv clones
By Onocyclone in forum Machine DiscussionReplies: 0Last Post: 06-09-2014, 05:20 PM -
NEW MEMBER: complete beginner saying hi
By helder1977 in forum New Member IntroductionsReplies: 6Last Post: 06-04-2013, 11:41 PM -
NEW MEMBER: complete newbie here :)
By chudds in forum New Member IntroductionsReplies: 0Last Post: 18-05-2012, 08:37 PM -
Complete conversion kits?
By leitzscope in forum General DiscussionReplies: 3Last Post: 01-05-2010, 07:57 PM
