12-02-2017 #2
Is there anybody who sell hardware to convert that mill - LongVersion?
Looking for ballscrews, mounting plates for: ballscrew, nuts and motors.
Ideally if handle can remain so can be used as conventional mill.
13-02-2017 #3
I am working on that right now. Two versions in the pipeline, servo and expensive ballscrews, steppers and cheap ballscrews. Both with handles.
ATV the moment I am designing based on my EMV-25VBB but also have the parts that will allow use on the ama series.
The trick is not to have to machine the casting and that is what you can expect from my kithttps://emvioeng.com
14-02-2017 #4
I understand that kit won't be kind of straight fit, as Y slide have to be machined to fit ballscrew nut.
My idea of buying such a kit is to do minimum work and fairly quick change over, so kit have to be design and machined to exact mill - AMA25LV.
I have control box with nema 34 motors and all home/limit switches.
I decided to use cheap steppers with digital drive rather than servos as this machine is not accurate anyway so no point to spend extra money as I won't gain anything decent.
Please give mee the quote for mechanical parts:
brackets/plates
both ballscrews c5 or c3 and c7
Tom
15-02-2017 #5
Tom,
I do not know which kit you are refering to. I have a way to avoid machining the castings.
Nema 34's will be overkill but I will provide an adaptor if you are desperate to use the kit your bought.
As I said, I am developing it currently so pricing will come when it is all sorted.
Send me a PM with your email address an I will keep you informed of progress.https://emvioeng.com
16-02-2017 #6
16-02-2017 #7https://emvioeng.com
AMA25LV CNC Project !!!
By Onocyclone in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 27-09-2014, 08:21 PM -
AMA25lv clones
By Onocyclone in forum Machine DiscussionReplies: 0Last Post: 06-09-2014, 05:20 PM -
NEW MEMBER: complete beginner saying hi
By helder1977 in forum New Member IntroductionsReplies: 6Last Post: 06-04-2013, 11:41 PM -
NEW MEMBER: complete newbie here :)
By chudds in forum New Member IntroductionsReplies: 0Last Post: 18-05-2012, 08:37 PM -
Complete conversion kits?
By leitzscope in forum General DiscussionReplies: 3Last Post: 01-05-2010, 07:57 PM
