    fifa's Avatar
    Lives in bristol, United Kingdom. Last Activity: 26-11-2017 Has been a member for 8-9 years. Has a total post count of 31. Received thanks 3 times, giving thanks to others 0 times.
    Good day Jon
    Leadshine is far to expensive for hobby machine like that. Machine spindle is not capable to do HSC, limit yourself for federates up to 2m/min >>ballnut drive = 400 rpm. More than enough.
    Any step motor driver with at least 64 steps can do approx sine curve, means you are on the safe side against resonance. Chose the motor which has enough torque also at highest speed, otherwise you will loose the steps.
    Backlash do not depend on the "C" class. It depends on the nut. For "diy" variants it is much cheaper to instal 2 nuts per axis (additional costs ca 30-60 GBP ) and pre-stress them for ca 10% of nominal load. Prestress ration can easily be checked with compactor and spring scale.
    regards
  1. AMA25LV CNC Project !!!
    By Onocyclone in forum Milling Machines, Builds & Conversions
    Last Post: 27-09-2014, 08:21 PM
  2. AMA25lv clones
    By Onocyclone in forum Machine Discussion
    Last Post: 06-09-2014, 05:20 PM
  3. NEW MEMBER: complete beginner saying hi
    By helder1977 in forum New Member Introductions
    Last Post: 06-04-2013, 11:41 PM
  4. NEW MEMBER: complete newbie here :)
    By chudds in forum New Member Introductions
    Last Post: 18-05-2012, 08:37 PM
  5. Complete conversion kits?
    By leitzscope in forum General Discussion
    Last Post: 01-05-2010, 07:57 PM
