Thread: 5v power suply
hi all im back again, might seem a bit dumb of me but what would be the best way to get the 5v supply to the breakout board and drivers, i currently have a 5v supply from usb split to 1 b/board and 3 stepper drivers, would this be ok or can u recommend a better way. also i have done a basic mach setup and trial and all i can get the motors to do is turn about half a turn a min evan if i turn up all the velocity etc, im guessing i have done something wrong, please help
30-03-2015 #2
Whilst I think that splitting the USB output to the BOB and drivers should be OK, when I did that on my machine I measured around 4V out of the USB which seemed a bit low. So to give it all the best chance of working I found a 5V supply on one of the cables in the PC (check some of the spare white molex plugs coming out of the power supply with a voltmeter to find one) and made up a lead to the BoB and drivers.
The other way to do it if you don't mind a bit of mains wiring is to use a switched mode power supply like this inside your control box:
http://www.ebay.co.uk/itm/Mean-Well-...#ht_5621wt_986
As for the speed post a picture of the stepper and driver wiring - sounds like something is not right there. Unless you are in 'step mode' in Mach3? Press the tab key and look at the settings for the MPG -should be 'constant'. For reasons I have never got to the bottom of my Mach3 always starts in 'step' mode and I have to change it to 'constant'.
30-03-2015 #3
thanks for the reply, yes i think im going to invest in the power supply from the link :) i think ive either got wiring issues or mach3 setup issues, there is i long starting delay (upto 5 seconds) when jogging (counters are going up but no motor movement initially) and motors run on a couple of seconds after, they dont seem to be smooth in motion, i will try and post pics tommoz as i have only done a test wiring, cables are not neat or in a box
31-03-2015 #4
Yes get your self 5vdc supply ASAP don't Trust USB for providing power to anything requiring constant supply like BOB or Drives it's not stable enough and prone to dropping out.
Where abouts are you in sheffield area.?
31-03-2015 #5
hi jazz, yes ill pic something up today, im near to worksop, not far off jct 30
31-03-2015 #6
31-03-2015 #7
hi all, i purchased a 5v supply and have it hooked up, its still taking mach 3 well over a min to turn 1 revolution if it bothers to turn at all and has a 8 second delay befor it starts, ive watched numerous videos on the wiring and mach config but its not changing a thing
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
rep power ???
By TrickyCNC in forum General DiscussionReplies: 11Last Post: 19-09-2012, 03:57 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
i need more power LOL
By Scott in forum General ElectronicsReplies: 2Last Post: 12-04-2010, 02:41 PM -
Power For Drivers
By SirMorris in forum Motor Drivers & ControllersReplies: 9Last Post: 24-08-2007, 08:53 PM
