  1. #5
    Thanks guys!
    Quote Originally Posted by Blackrat View Post
    looks great, what size tools and speeds/feeds
    1/4 V cutter 60 degree, 3mm flat depth. Thats the typical i use for engraving soft, hard wood and phenolic plastic. A balance between fine detail, angle, speed, depth and quality look for thin and thick wood. I could say i have engraved thousand of things from credit card size to 1m signs, from arabesque to mandalas and signs, that works for all.
    I just speed it 17000 for hard wood and 18000 for very hard wood /ipe and ebony/ and slow at half the feed for phenolic. This is not flat V cutter, its a spiral one.
    The profile was done by my favorite 1/4 3 flute straight Kyocera bit at 16000 rpm and 90IPM. i am running short of this one unfortunately, so have to search from where to buy more, cause Drillman1 sells overstock so not always has what i like.
    The pictures dont do justice to the perfectly polished bits that last much more than say Freud or similar.
ID:	15095   Click image for larger version.
  1. RFQ: Wood CNC routing service (wood Letters)
    By coujin in forum Projects, Jobs & Requests
    Last Post: 16-02-2015, 03:35 PM
  2. wood sign cut with cnc router
    By jonm in forum Woodworking Project Showcase
    Last Post: 09-06-2014, 08:05 PM
  3. RFQ: Wood Sign/engraving required, small job one off money waiting...
    By njhussey in forum Projects, Jobs & Requests
    Last Post: 21-09-2013, 07:12 PM
  4. My first sign
    By Web Goblin in forum Metalwork Project Showcase
    Last Post: 03-04-2013, 09:05 PM
  5. Convert Wood Lathe from hand held tooling
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 14-02-2010, 11:53 AM
