Thread: Vertical moving gantry????
Basically it's just more sliding joints to cause a problem.
If the gantry doesn't need to move during a job then it doesn't need precision rails, it just needs to be adjustable with clamps to secure it in place.
You could have an extended Z axis (requiring long strong precision slides) or make the whole gantry as the Z axis. The mass will be similar to a Y gantry,so will require a similar motor/drive. It would require spring/air/mass to balance gravity and you'd have to find a way to stabilise the Y axis (i.e. dual lead-screws). Complex maybe, but do-able.
02-06-2009 #2
Just a quick thought, instead of moving the gantry up to give you more room why not move the bed down??
By this i mean make a false bed which sits on top of your existing bed, with the false bed you would get say 0-150mm and without it 150-300mm. You have to remove it everytime you put a large workpiece in and it wouldn't give you the flexibilty to do the whole 0-300mm on one job.
It also would mean making your gantry sides a lot higher which would reduce the rigidity.
Personally i wouldn't bother though....!
02-06-2009 #3
Thanks guys, I have considered most of those ideas so its good to know im thinking along the right lines.
Kip
did you mean 1mm or 1 m? What are rod less cylinders(probably regret asking that...) are they air driven?
this sounds the most favorable, Think I saw someone on here suggest multiple holes on the Z to gain more bed height, perhaps allow fixings on the end at 50mm increments and then move it when neccessary.Basically it's just more sliding joints to cause a problem.
Not keen as there will definatly be a rotary table going in for 4th axisJust a quick thought, instead of moving the gantry up to give you more room why not move the bed down??
Any one used dual X axis to extend travel?, ie. Moving gantry and moving table.
03-06-2009 #4
Snap! Mine are 550mm stroke tho. Very nice things; just not yet sure what to do with them. The ones I have are made by SMC.
Shame air is too springy to allow positional accuracy.
What do you plan on using yours for?
Back to the original posters question I would go for a movable bed too.
I saw a very handy post and/or image on cnczone(maybe?) that had a side view of a moving gantry machine with lots of forces drawn on it ie given 50N force on cutter then with n length of Z axis the twisting forces on the gantry will be (x)N.
It was well worked out and made the point you wanted the centre of gravity of the Z axis to be between the two gantry bearing trucks etc.
Saw it once, was impressed, and now I actually need it to help me design a machine I cant find it anywhere.
Anyone know what Im talking about?
Jim
PS Kip, do you live on a boat? That photo looks like it was taken looking to the side of a narrow boat or a broads cruiser.Last edited by rinderpest; 03-06-2009 at 12:39 PM. Reason: Noticed Kip may live on a boat.
Help! Moving a big lathe...
By Jonathan in forum General DiscussionReplies: 21Last Post: 27-12-2015, 11:54 PM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
moving mach3 help please
By h4ppy-chris in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-03-2011, 07:33 PM -
Moving a new mill
By abfa9358 in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 07-05-2010, 11:27 PM
