    Just a quick thought, instead of moving the gantry up to give you more room why not move the bed down??
    By this i mean make a false bed which sits on top of your existing bed, with the false bed you would get say 0-150mm and without it 150-300mm. You have to remove it everytime you put a large workpiece in and it wouldn't give you the flexibilty to do the whole 0-300mm on one job.
    It also would mean making your gantry sides a lot higher which would reduce the rigidity.
    Personally i wouldn't bother though....!
    Thanks guys, I have considered most of those ideas so its good to know im thinking along the right lines.
    Kip
    did you mean 1mm or 1 m? What are rod less cylinders(probably regret asking that...) are they air driven?
    Basically it's just more sliding joints to cause a problem.
    If the gantry doesn't need to move during a job then it doesn't need precision rails, it just needs to be adjustable with clamps to secure it in place.
    this sounds the most favorable, Think I saw someone on here suggest multiple holes on the Z to gain more bed height, perhaps allow fixings on the end at 50mm increments and then move it when neccessary.
    Not keen as there will definatly be a rotary table going in for 4th axis
    Any one used dual X axis to extend travel?, ie. Moving gantry and moving table.
    Snap! Mine are 550mm stroke tho. Very nice things; just not yet sure what to do with them. The ones I have are made by SMC.
    Shame air is too springy to allow positional accuracy.
    What do you plan on using yours for?
    Back to the original posters question I would go for a movable bed too.
    I saw a very handy post and/or image on cnczone(maybe?) that had a side view of a moving gantry machine with lots of forces drawn on it ie given 50N force on cutter then with n length of Z axis the twisting forces on the gantry will be (x)N.
    It was well worked out and made the point you wanted the centre of gravity of the Z axis to be between the two gantry bearing trucks etc.
    Saw it once, was impressed, and now I actually need it to help me design a machine I cant find it anywhere.
    Anyone know what Im talking about?
    Jim
    PS Kip, do you live on a boat? That photo looks like it was taken looking to the side of a narrow boat or a broads cruiser.
    Last edited by rinderpest; 03-06-2009 at 12:39 PM. Reason: Noticed Kip may live on a boat.
  1. Help! Moving a big lathe...
    By Jonathan in forum General Discussion
    Last Post: 27-12-2015, 11:54 PM
  4. moving mach3 help please
    By h4ppy-chris in forum Artsoft Mach (3 & 4)
    Last Post: 07-03-2011, 07:33 PM
  5. Moving a new mill
    By abfa9358 in forum Milling Machines, Builds & Conversions
    Last Post: 07-05-2010, 11:27 PM
