Thread: Hiwin Lubrication
Yes, thats the one. That happens, it must come out from somewhere, just make things slowly so you don't damage the seals. The Bearings block is preloaded so its not meant to be judged by hand movement. I just make that from both sides to be sure its full of grease.
Now the thing is that i stopped using nozzles at all. I just needled the side plastic holes both sides and use a small grease gun with conical tip pressed against the plastic. Works like a charm. Easy to rech and grease. No dust could go inside from the small needle hole.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
27-04-2015 #2
is this OK for ballscrews as well?
27-04-2015 #3
WANTED: Mist lubrication system
By badgerman in forum Items WantedReplies: 9Last Post: 21-08-2014, 12:28 AM -
Hiwin HGH vs. EGH
By dsc in forum Rails, Guideways & BearingsReplies: 0Last Post: 24-03-2013, 07:41 PM -
Milling machine -maintenance? (oil, lubrication, specific questions)
By diy-john in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 24-02-2013, 09:03 PM -
Ballnut Lubrication / Grease
By Mad Professor in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 18-07-2012, 08:08 PM -
Lubrication (OOooeerr missus)
By Smiler in forum Linear & Rotary MotionReplies: 3Last Post: 14-10-2008, 07:56 PM
