13-04-2015 #8
Ok well the G540 needs continuity between pins 10 & 12 other wise Motors are disabled and why the Red light comes on, this is normally used for the E-stop circuit with normally closed switch. .!
Easy way to check this is to put a Jumper wire between pins 10 & 12. If this works then you have a broken wire or faulty switch. Pin 10 must go to ground which is Pin12 on G540 so if still not working then check the Ground wire not broke or loose.!
Advice needed on Amadeal
By croy in forum General DiscussionReplies: 13Last Post: 21-08-2015, 01:28 PM -
bit of advice needed for first mill
By jmac80 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 06-04-2014, 10:59 PM -
First steps, advice needed
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 02-11-2012, 02:30 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM -
SPG X3 CNC Mill, advice needed please
By shaggyhawkings in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 07-01-2010, 11:00 PM
