12-04-2015 #2
N20 G91 G28 X0.000 Y0.000 Z3.001
G91 tells the machine to move in reference mode
G28 tells it to return to reference point ...
read more there:
http://www.cnccookbook.com/CCCNCGCodeG28ReturntoReference.htm
read that also
http://www.cnccookbook.com/CCCNCGCodeG00G01.htm
this exactly is the code that tells your machine to start from work 0
N90 X0.000 Y0.000 F3600.0
if you dont understand from first read whats happening, then dont mess around, just change the HOME position of your machine to left nearest corner instead of middle of the machine.
or you could just raise the jog rate to the max by the motor tuning /velocity/ so all free non cut positioning movements will happen a lot faster.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
Anyone got some 2.5D G-code please ?
By dudz in forum Programmers CornerReplies: 5Last Post: 22-06-2013, 11:21 PM -
Z safe in g code question
By Fivetide in forum CAD & CAM SoftwareReplies: 7Last Post: 20-02-2013, 08:00 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
iges or stl to g.code
By Dan Brown in forum Computer SoftwareReplies: 5Last Post: 08-01-2010, 11:20 PM -
G Code help
By moose007 in forum Programmers CornerReplies: 4Last Post: 22-05-2009, 11:39 AM
