13-04-2015 #3
http://www.mycncuk.com/threads/8613-...-NEEDED-PLEASE!!!!
You should check posts #3,#4, and #8 which suggest you short out the e-stop pins on the break out board. As Jazz advises this is pins 10 and 12.
If you are hesitating because you are unsure about electrics then -
You need a short length of cable, with the last bit of insulation removed.
Turn off all power to the box and unplug it from the mains.
Wait a minute or two for any discharging to finish.
Secure one end of the cable into the screw terminal for pin 10 and the other end into the terminal for pin 12.
Stand clear, and plug in and switch on.
The red light/estop may clear.
This is a 2 minute job so if this does not work then report back.Last edited by routercnc; 13-04-2015 at 09:36 PM.
Gecko G540 or?
By JW1977 in forum Gantry/Router Machines & BuildingReplies: 34Last Post: 17-09-2017, 05:28 PM -
FOR SALE: Gecko G540 Controller & Accessories
By jeboa in forum Items For SaleReplies: 3Last Post: 21-09-2013, 09:45 AM -
eBay: New Gecko G540 Controller (Rev 8 With Arctic Silver Mounted Heatsink) $1 No Res 3 Day
By Storm2313 in forum Items On eBay UKReplies: 4Last Post: 08-05-2013, 11:31 AM -
Gecko G540 - local source
By compfranon in forum Motor Drivers & ControllersReplies: 26Last Post: 10-09-2011, 07:06 PM -
Gecko G540
By Sparks in forum Motor Drivers & ControllersReplies: 14Last Post: 29-11-2010, 04:52 PM
