    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 19 Hours Ago Has a total post count of 804. Received thanks 101 times, giving thanks to others 176 times.
    Sorry can't see your logic there, even if you use the hollow rivet method i think you will find that they protrude from the board also, and forgive me if i am wrong but all the pcb assemblies i have seen the wires from the components also protrude through the board with a solder fillet.
    But i am only a klanky so what do i know.
    Good luck on whatever you decide.
    Regards
    Mike
    Whilst not the same project at all, this guy has the same challenge & you can therefore get a flavour...
    http://www.cycfi.com/2014/08/neo-base-boards/
    ...mine will be a similar shaped pcb to that - and one of these covers goes atop ..... http://www.themusiczoo.com/product/1...-Covers-White/ )
    The logic of using the rivet is that it probably sits proud less than 1mm on the top surface (ok, so I said in my former post that the enclosure butts up against the pcb.....indeed it does, but at the perimeter only, there's probably about 1mm of 'head' clearance where the holes are)
    Last edited by HankMcSpank; 20-04-2015 at 07:38 PM. Reason: Unfeasibly Mary Hinge.
    mekanik's Avatar
    I know you don't have a lathe so this is probably not going to help but i think the best solution would be a top hat type of insert drilled and taped 3mm the flange could be 0.5mm thick so minimal protrusion, clearance hole in the board to locate it while soldering top hat in place.
    Regards
    Mike
  4. The Following User Says Thank You to mekanik For This Useful Post:
  5. #14
    mekanik's Avatar
  6. #15
    thanks but they looks broadly similar to the nuts I referred to in my opening post...
    http://www.rapidonline.com/mechanica...4658e0d0b4ee75
    (actually the ones at Rapid Online have smaller hole 4.2mm vs 4.6mm for M3)
    like I say, the spec for those things suggest my pcb holes are going to be too close to the edge of the board.
  7. #16
    Have you considered M3 RivNuts?
    I've set M6 Riv-Nuts in Polycarbonate, Fibreglass and ABS by using a washer on the back and crimping tight enough to hold but not tight enough to damage, the hole in the base material is drilled clearance and it's the tension of the Riv-Nut between head and washer that holds by friction on the surfaces.
    I used washers cut from Polyurethane sheet on both sides of the Polycarbonate and Fibreglass to prevent wear with vibration, rain and road dirt but I suspect you won't have those issues ;-)
    Regards,
    Nick
  8. #17
    mekanik's Avatar
    Was just looking for the makings really, it's a simple job to chuck these on a mandrel in the lathe,remove the serations and even skim the flange OD if that's too large.
    Regards
    Mike
  9. #18
    You don't need to skim the serrations, you need to adjust the drilled hole size to suit the material you're using to avoid splitting, you'll still have significant resistance to turning from the mechanical fit, add a 2-part adhesive for adequate retention and you're sorted.
    If you use a backing washer, as I stated, the hollow section spreads and partially collapses outside the washer and doesn't spread in the substrate, no stress on the hole, just compression of the board, so no splitting.
    I guess that's similar ;-)
  10. #19
    I have the mandrel for the setting tool.
    Whilst you can buy and use a Riv-Nut setting tool all you need is a flat steel bar with a hole through it and roughed up a bit on the side presented to the Riv-Nut head, preventing slipping when setting.
    Use a bolt or bit of threaded bar through the flat bar and fully engaged with the Riv-Nut threads.
    With lubed washers & well lubed nut on top, tighten nut whilst ensuring the bolt doesn't turn and set the Riv-Nut to the tension or height of your choice.
    I use 60% Moly paste for the lube as it gives the best possible friction reduction and thus translates as much torque as possible into tension.
    - Nick
  11. #20
    mekanik's Avatar
    My idea was to solder the insert, removing the serations means you can have a smaller hole in the board so the board is stronger. the inserts could be machined to practically any size you want.
    Regards
    Mike
  1. Haunyang VFD input voltage
    By JamesUS in forum Spindles & Drive Motors
    Last Post: 18-01-2015, 08:25 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. Stepper controller to manually input a specific degree
    By Web Goblin in forum Motor Drivers & Controllers
    Last Post: 13-10-2013, 05:47 AM
  4. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 08:31 PM
