My idea was to solder the insert, removing the serations means you can have a smaller hole in the board so the board is stronger. the inserts could be machined to practically any size you want.
Regards
Mike
21-04-2015 #2
Brass bar stock is cheap enough, I suspect you could knock out a few dozen in an hour once you have the tooling and a procedure set for your lathe.
The topic title does lead one to think down a riveting specific mechanical route ;-)
21-04-2015 #3
You are correct the OP was looking for an off the shelf solution and your method is proven so it looks like the best choice in that regard, have my doubts about the rivet method only because of the wall thickness of the hollow rivet, the method i offered puts no strain @ all on the PCB. if OP sends me some of the inserts i pointed too i will gladly machine them to the size required.
regards
Mike
Haunyang VFD input voltage
By JamesUS in forum Spindles & Drive MotorsReplies: 0Last Post: 18-01-2015, 08:25 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM -
Stepper controller to manually input a specific degree
By Web Goblin in forum Motor Drivers & ControllersReplies: 11Last Post: 13-10-2013, 05:47 AM -
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM
