    Slightly off off topic, but have you considered getting the PCB manufactured? It's pretty cheap in China.
    You can get riveting tools to use as a method for making vias in PCBs, but they're too small. Maybe something to imitate.
    Instead of riveting, perhaps you could use a lathe to machine your own insert from brass and solder it to the board on both sides, or would that not be strong enough?
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  3. #2
    Hi Jonathan...thanks (as ever) for the input.
    Truth be told, I don't trust Chinese fab houses.
    This is fairly low run....I'm probably talking 40pcs maximum per annum .....it only takes me about 15 minutes to mill 10 nested copies of my pcb layout, therefore just over an hour to mill one years supply of the pcbs needed!
    Actually, I think I've found the tool I need....
    http://www.mouser.com/ProductDetail/...8SqT5kVQ%3D%3D
    which crimps these eyelets.....
    http://www.mouser.com/Search/Product...tP4fbZOg%3d%3d (1/8" ....they'd probably do for M3)
    The rivet press for riveting thru hole rivets for PCBs costs about £500!
    Re using a lathe...I don't have one, & that sounds time intensive (& I'm trying to get the time down to build one of my widgets....it already takes me about 1.5hrs (I'd rather use something already available & cheap as chips...hence looking at brass/copper rivets/eyelets) ....also I suck with a lathe
    (Incidentally, I've found a cheapskates method for PCB stencils....from drinks cans! https://www.youtube.com/watch?v=JWUJtmgh55M .....except he's etching, that could readily be milled)
    I read your requirements about position of the hole and I thought maybe a steel M3 riv-nut could be soldered into the PCB. The one I have are 4.7mm OD and 8.7mm long. I have the mandrel for the setting tool, but they are fragile and hard to come by, but it sounds as though setting them in the PCB would not be an option anyway.
  5. The Following User Says Thank You to cropwell For This Useful Post:
  6. #4
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 17 Hours Ago Has a total post count of 803. Received thanks 101 times, giving thanks to others 176 times.
    Looks like the best option is going to be soldering to the board, i would get some 2 or 3mm brass plate cut off a strip drill and tap several holes and the cut it to a length that dives you a reasonable surface area, then solder it to the board.
    You could do the drilling on your cnc and knock off a bath in a reasonable amount of time.
    Regards
    Mike
  7. The Following User Says Thank You to mekanik For This Useful Post:
  8. #5
    Any leather eyelet pliers will do the job and if they don't reach, then refabricate something similar with longer reach from them . If it was me i would simply instant glue each side a washer. If the glue is good it would stick forever.
    Plus, nobody could convince me that the PCB eyelet which they sell for 10cents is not in fact leather eyelet.
ID:	15153   Click image for larger version.
  9. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  10. #6
    I have the mandrel for the setting tool.
    Whilst you can buy and use a Riv-Nut setting tool all you need is a flat steel bar with a hole through it and roughed up a bit on the side presented to the Riv-Nut head, preventing slipping when setting.
    Use a bolt or bit of threaded bar through the flat bar and fully engaged with the Riv-Nut threads.
    With lubed washers & well lubed nut on top, tighten nut whilst ensuring the bolt doesn't turn and set the Riv-Nut to the tension or height of your choice.
    I use 60% Moly paste for the lube as it gives the best possible friction reduction and thus translates as much torque as possible into tension.
    - Nick
  11. #7
    mekanik's Avatar
    My idea was to solder the insert, removing the serations means you can have a smaller hole in the board so the board is stronger. the inserts could be machined to practically any size you want.
    Regards
    Mike
  12. #8
    Brass bar stock is cheap enough, I suspect you could knock out a few dozen in an hour once you have the tooling and a procedure set for your lathe.
    The topic title does lead one to think down a riveting specific mechanical route ;-)
  13. #9
    mekanik's Avatar
    You are correct the OP was looking for an off the shelf solution and your method is proven so it looks like the best choice in that regard, have my doubts about the rivet method only because of the wall thickness of the hollow rivet, the method i offered puts no strain @ all on the PCB. if OP sends me some of the inserts i pointed too i will gladly machine them to the size required.
    regards
    Mike
  1. Haunyang VFD input voltage
    By JamesUS in forum Spindles & Drive Motors
    Last Post: 18-01-2015, 08:25 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. Stepper controller to manually input a specific degree
    By Web Goblin in forum Motor Drivers & Controllers
    Last Post: 13-10-2013, 05:47 AM
  4. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 08:31 PM
