    i2i's Avatar
    Quote Originally Posted by HankMcSpank View Post
    Long time no post how you all doin'?!!! :-)
    I need your input!!
    I've a little widget that I used to make ...basically a pcb with 2 x m3 holes tapped into it ....it's looking like that I'm going to have to dust it down & start selling again (sigh).
    Problem: Tapping M3 holes directly into 1.6mm thick pcb is not strong enough (especially since I use paper based FR2 board vs. fibre glass based FR4...this is because FR2 is a whole lot cheaper & presents a far nicer grade of dust for inhaling when I mill it!) .....at the moment I tap the m3 holes, & put nuts onto the screw behind to reinforce the hole - not ideal). So I need a more robust way of reinforcing the holes in the pcb.
    These self broaching nuts initially seemed a good option....http://www.rapidonline.com/mechanica...-of-50-33-3802 .. except the hole has to be 4.2mm to receive those nuts ....and they have to be a couple of millimetres away from the board edge (not sure I understand their "Min. radius thickness from sheet edge" ...is that to the edge of the nut or the centre of the nut?) ...this last bit is the deal breaker (I can't move the holes, and with a 4.2mm hole to receive those nut, it'd be too close to the edge of the pcb...it'll probably crack when inserting the nut under pressure).
    ok, second option, re-inforce the hole with a rivet, so I was looking at these copper rivets...
    http://www.aliexpress.com/store/prod...271034053.html
    their hole is 2.5mm diameter ...bearing in mind I need an M3 tap, that seems in the ballpark, but I then worry how much of the rivet would even left after the M3 thread was tapped inside it??
    My main problem though is how do you even crimp something like that? (it'd need a die /punch of some kind or other, but I can't even begin to work out where I'd source one from?!!)
    Cheers in advance!
    How about soldering 3mm brass nuts to the top or bottom of the board.
    Thanks guys....great input. I can't solder brass nuts, because it a single sided board ....and the solder side is on the wrong side for the nut to go on :-(
    silyavski ...I'd forgot that I've actually got one of those tools lying around somehwre (probably in my loft), I'll dig it out & give it a go!
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 17 Hours Ago Has a total post count of 803. Received thanks 101 times, giving thanks to others 176 times.
    Although the link to the intended rivets gives a reference (h) for the wall thickness the seller does not specify a size. Thread depth for 3mm thread is 0.3mm so it is going to have to be about 0.5mm wall thickness to give you a bit of lee way.
    Can to send a quick sketch on how you need to use the holes for fixing and why you cant solder a nut/plate to the board.
    Regards
    Mike
  4. The Following User Says Thank You to mekanik For This Useful Post:
  5. #4
    For now, I'd rather not post my drawings, but I can't solder a nut becuase like I say it's single sided pcb ....and on the copper side of the pcb, the enclosure will be butting up against the pcb surface.....if I soldered a nut on that particular side, then there's be a gap equal to the height of the nut that was soldered onto the pcb (which would look awful)
    Last edited by HankMcSpank; 20-04-2015 at 06:43 PM. Reason: Particularly Mary Hinge.
  6. #5
    mekanik's Avatar
    Sorry can't see your logic there, even if you use the hollow rivet method i think you will find that they protrude from the board also, and forgive me if i am wrong but all the pcb assemblies i have seen the wires from the components also protrude through the board with a solder fillet.
    But i am only a klanky so what do i know.
    Good luck on whatever you decide.
    Regards
    Mike
  7. #6
    Whilst not the same project at all, this guy has the same challenge & you can therefore get a flavour...
    http://www.cycfi.com/2014/08/neo-base-boards/
    ...mine will be a similar shaped pcb to that - and one of these covers goes atop ..... http://www.themusiczoo.com/product/1...-Covers-White/ )
    The logic of using the rivet is that it probably sits proud less than 1mm on the top surface (ok, so I said in my former post that the enclosure butts up against the pcb.....indeed it does, but at the perimeter only, there's probably about 1mm of 'head' clearance where the holes are)
    Last edited by HankMcSpank; 20-04-2015 at 07:38 PM. Reason: Unfeasibly Mary Hinge.
  8. #7
    mekanik's Avatar
    I know you don't have a lathe so this is probably not going to help but i think the best solution would be a top hat type of insert drilled and taped 3mm the flange could be 0.5mm thick so minimal protrusion, clearance hole in the board to locate it while soldering top hat in place.
    Regards
    Mike
  9. The Following User Says Thank You to mekanik For This Useful Post:
  1. Haunyang VFD input voltage
    By JamesUS in forum Spindles & Drive Motors
    Last Post: 18-01-2015, 08:25 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. Stepper controller to manually input a specific degree
    By Web Goblin in forum Motor Drivers & Controllers
    Last Post: 13-10-2013, 05:47 AM
  4. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 08:31 PM
