21-04-2015 #19
You don't need to skim the serrations, you need to adjust the drilled hole size to suit the material you're using to avoid splitting, you'll still have significant resistance to turning from the mechanical fit, add a 2-part adhesive for adequate retention and you're sorted.
If you use a backing washer, as I stated, the hollow section spreads and partially collapses outside the washer and doesn't spread in the substrate, no stress on the hole, just compression of the board, so no splitting.
I guess that's similar ;-)
Haunyang VFD input voltage
By JamesUS in forum Spindles & Drive MotorsReplies: 0Last Post: 18-01-2015, 08:25 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM -
Stepper controller to manually input a specific degree
By Web Goblin in forum Motor Drivers & ControllersReplies: 11Last Post: 13-10-2013, 05:47 AM -
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM
