    Quote Originally Posted by mordy View Post
    I hear what you say regarding the PC and interruptions etc, Ideally I would love the MACH3 on my Macbook Pro under parallels (emulation or virtual PC) using the USB and assigning it all resources when running, but I need to see what others are doing, and if they are being successful
    Yep I hear you but Emulation is a None starter I'm afraid with Mach3 so don't waste your time trying and looking.!!
    Reason it's a None starter is because of pulse timings.?. . Emulation doesn't and can't provide accurate enough pulse timings no matter how many resources you throw at it. To be honest even the parallel port under windows struggles and the ONLY reason it works with Mach3 is because of the trickery of the parallel port driver. Which is basicly a Virus inside windows which takes over the system and rules the roost.
    So you see the parallel port driver which is the heart of the system won't work inside emulation.
    Regards USB then even if using Windows PC you can't run Parallel port thru USB using a converter etc. Again due to timings and how critical pulse timing works. The ONLY way you can use USB is with a device like the UC100 which is a hardware & software device.
    The only way you can get your Macbook to work is with an external motion control device like the Uc100 etc.
    Please take my word on this to save your self some serious stress and time by not even going down this route.
    My first choice and strong advise is to buy an external Motion control and Ethernet based one not USB as Ethernet is so much better. There really is no comparison to parallel port and you'll have much more stable machine that performs like a rocket.
    Second and only other choice is stand alone PC with 5V parallel port, not 3V. It's very important the voltage coming out of parallel port is 5V or very close to it. 3V is not good enough but unfortunatly they are common on newer PC's.
    Reason 3V isn't good is because of the Logic state falsely switching.? CNC machine works by Digital ON/OFF or HIGH/LOW signals and these work by 0v to 2.5v = Low and 3v to 5V= HIGH.
    With 3V PP there isn't enough difference between HI-LOW and any electrical noise floating around will cause havoc with signals and switching it's state falsely causing all sorts of havoc and air pulling.!!
    Think of the Motion control side like the human heart.? If your heart doesn't pump correctly then no matter how good the rest of the body it simply won't perform like it should.!
    The parallel port is like the heart of some one who eats well enough but smokes 40 a-day and doesn't exercise. It will get you by day to day but try to run too fast and you'll struggle badly. Try to Run a marathon without training and you'll likely die.!!
    Ethernet Motion control card is like fitness fanatic who looks after him self and runs marathon every day.!!
    Edit: Just to Add IMO the Parallel port is dieing Technology so best avoided. Like wise USB is unstable for timing critical devises so again best avoided. Ethernet is designed for high speed pulse signals and perfect at it even over distance.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    Thanks so much for the great time saving advice. You have given me a new set of things to think about. Please give me a bit of time to formulate an intelligent response, most likely including several questions.
    Thanks Jazz and Mikey.
    I like the Analogies
    Hi Jazz, so I'm looking at the Ethernet version of Smooth Stepper, Peter has them here, cost around $260, and this is what I'm thinking, run MACH3 in a virtual machine (not emulation) using parallels on the MacBook Pro, with Win7 (32bit), connect the MAC via Ethernet Port to smooth stepper to my Gecko 540 to motors.
    Thats where I am at, at the moment. Am I going down the correct road or is even the whole idea of the virtual machine (VM) no good ?. (bearing in mind what you have already said) I'm asking about the VM method as I have seen couple of videos now with MAC's running VM's with MACH3 and motion controllers.
    Thanks again, sorry if I am being a bit tedious.
  5. #4
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    I do believe that Jazz has already answered this quite comprehensively, but really...
    DON'T DO IT.
    There are the straightforward ways of doing things, and there are ways that invite all sorts of ball-ache.
    Wal.
  6. #5
    having in mind an old PC , Dell 2-3ghz, 1-2gb ram together with the screen and Xp installed , at a bootsale is under 50euro , i don't see even why running a VM could pass through your mind. Ahh, yeah, i get, you are one of the Apple people
    DON'T DO IT.
    Wal.
    I hear ya Wal. But there is a couple questions i'd like to explore, expanding on the previous answer, I am sure if Jazz has decided he "has answered quite comprehensively" he will not reply or tell me so.
    No need to shout about it. I know it's frustrating with newbies, but I am sure you were one once etc.
  8. #7
    Well first I will answer you even if I think I've answered enough because i realise living upside down on other side of world must make the blood run to your head so there must be brain damage which makes learning harder.. .
    Now being serious. The ESS smooth stepper is ok and will work for you even with Macbook.
    Running Mach3 in emulation isn't the problem it's the parallel port driver that's the problem. But the fact you will be using ESS (or any external motion controller) removes this problem because it uses it's own software that runs inside of mach3 and the hardware generates the pulses.
    That said I still VERY STRONGLY advise you to get a stand alone PC just for the CNC machine.
  9. The Following User Says Thank You to JAZZCNC For This Useful Post:
  10. #8
    And here is me thinking its my Half British Half Spanish Background that has been hindering me all my life, now I see, it was all those negative G's from airforce flying exacerbated by the 'down under' affect that's done it.
    I'll go to trash and treasure this weekend for a PC. (bring the voltmeter) even though I will eventually be using the ethernet rather than PP. (thats the plan, but it is just a plan)
    Thanks guys for your help so far.
  11. #9
    Wal's Avatar
    I still consider myself very much a noob - yes, I've built a small vertical mill which is servicing my needs very well indeed, but it was only built thanks to the help and advice of the good people on here.
    At the best of times it's a delicate process getting things dialled in and 'just-so' - I'm thinking that the software set-up you're proposing will add an extra layer of quirky behaviour that could have you going round in circles... And your nice clean MacBook will be filthy within hours..!
    Good luck with it, whichever way you decide to go!
    Wal.
  12. #10
    Wal.
    Thanks Wal.
    Poor MacBook it has a hard life in my shed, you reckon I should give it a break....
  1. Corian and similar products
    By Fivetide in forum General Discussion
    Last Post: 20-10-2012, 03:36 PM
  2. Cutting bits nomenclature - help requested
    By DanielF in forum Tool & Tooling Technology
    Last Post: 12-05-2012, 04:53 PM
  3. Links directory
    By ptjw7uk in forum General Discussion
    Last Post: 19-02-2011, 11:09 AM
